Audio Channels
Christian Lauritsen
Audio Channels
on Aug 4, 2018 at 12:58:51 am
Hi!
I'm trying to edit some soccer footage, but having some trouble with the audio channels.
When I open the file (.mov) in ie VLC, I can choose between two audio channels (one with, and one without commentator). But when I import the .mov to FC (10.4.3) I have only one working channel. Channel 2 is without sound...
Any tips?
Jeff Kirkland
Re: Audio Channels
on Aug 4, 2018 at 9:53:46 pm
If one channel worked, you’d expect them both to... My only thought would be to open the file in your audio editor of choice and export the tracks individually, then import to FCPX.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Jeremy Garchow
Re: Audio Channels
on Aug 5, 2018 at 1:22:13 pm
Have you set the channels to dual mono in FCPX?
Christian Lauritsen
Re: Audio Channels
on Aug 6, 2018 at 8:02:01 am
In dual mono I have two channels, but they both have the same sound. The commentary channel is nowhere to find...
Tried this on another MacBook now, and having the same issue....
Mark Smith
Re: Audio Channels
on Aug 6, 2018 at 11:40:37 am
Was the original video captured as, P2 by any chance?
Jeremy Garchow
Re: Audio Channels
on Aug 6, 2018 at 11:44:02 am
This was going to be my next question as well.
What format is the media from and what version of FCPX are you using?
Christian Lauritsen
Re: Audio Channels
on Aug 6, 2018 at 12:02:09 pm
It's downloaded TV broadcast...
This are the info I have. (Sorry for Norwegian wording, but I think you get the keys)
Printscreen: https://imma.gr/72745xda035
My version of FCPX is 10.4.2
Jeremy Garchow
Re: Audio Channels
on Aug 6, 2018 at 12:33:34 pm
If you can, download fcp 10.4.3, reimport and try again.
