change background of non green screen
Paul Bosch
on Jun 28, 2018 at 1:06:03 pm
Hi I have a project I need to change the background of somthing that is not green screen. If I do a garbage mat the subject moves and throws the whole thing off. I cants seem to successfully key it. i
  • Return to posts index
    John Rofrano
    Re: change background of non green screen
    on Jun 28, 2018 at 2:31:16 pm
    [Paul Bosch] "I need to change the background of somthing that is not green screen."
    What you want to do is called "rotoscoping" and if you search for "rotoscoping fcpx" you will find tutorials on how to accomplish this. The easiest would be with a tool like SliceX from CoreMelt which is powered by Mocha.
    Here is a tutorial on how to use SliceX for rotoscoping:
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
