Effects suggestions
Russell Smith
Effects suggestions
on May 24, 2018 at 9:48:13 pm
Hi Guys, Im filming some content and want to know how to achieve this effect on the screen behind taylor swift, I went down the road of separating RGB channels but don't think this is it and maybe someone has some suggestions. I don't want to have to key the dancer out and change the color. there must be an easier way.
Thanks in advance.
It would not let me copy link at specific time, its 56 sec into the video.
https://
Jeremy Garchow
Re: Effects suggestions
on May 25, 2018 at 1:20:38 am
Are you snorting green screen or what’s the background?
Russell Smith
on May 25, 2018 at 2:52:18 am
Dark black BG
Jeremy Garchow
on May 25, 2018 at 5:13:41 pm
Perfect. Good thing you aren’t snorting green screen. Bad for the health! ☺
You could do this manually with Motion and a either clones or replicator, but a quick search turned up a plugin that might be better for you.
https://store.pixelfilmstudios.com/product/proarray/
Jeff Kirkland
on May 25, 2018 at 10:25:16 pm
Can't help with a specific recommendation but the effect is reminiscent of Motion's WideTime filter and I know it's a an effect I've seen a lot in various live VJ apps.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Brett Sherman
on May 27, 2018 at 1:32:53 pm
If you are so inclined, you could make a Motion Template that does this. Looks to me like the original layer is keyed on top with a luma key. Then cloned layers underneath also with luma key and Colorization, with a horizontal offset. You'd also want to keep a clone of the original layer on the bottom too, without a key.
