Batch angle editing
Brendan O'Kane
Batch angle editing
on May 4, 2018 at 9:25:25 am
I have an edited multi-cam sequence In FCPX and I now wish to select a single audio angle for all of the clips. I can click on each individual clip and do this but as the project is pretty big there are hundreds of clips to be changed. Does anyone know of a way of selecting all clips and allocating the audio angle to all of them
Jeremy Garchow
Re: Batch angle editing
on May 4, 2018 at 11:53:17 am
Can you select them all, right click and choose the active audio angle?
Brendan O'Kane
on May 4, 2018 at 12:53:01 pm
I tried that Jeremy but the Choose Audio Angle option is greyed out and is unresponsive.
Brendan (Dublin IRELAND)
Jeremy Garchow
on May 4, 2018 at 1:18:31 pm
How many separate multicam clips are in the timeline, meaning how many multicam did you cut from (which is different than how many cuts are in the timeline). I would think if you choose each multicam in the inspector and select each instance of the same clip, you may be able to do it.
Brendan O'Kane
on May 6, 2018 at 5:49:41 am
Hi Jeremy. Your suggestion did the trick and the problem is solved. Thank you for taking the time to help. It is very much appreciated.
