designate track for keyboard shortcut edit
Jason Brown
on Apr 23, 2018 at 3:48:18 am
I have a series of clips in a secondary storyline and I need to go through and time them to another track. I'm using the keyboard shortcut opt+] to trim them back to meet my desired timing, but it requires me to select the clip everytime. Is there a way to auto designate that "track" as the location I want the trimming to happen. If I don't select that clip, it will trim my primary storyline.
Gregor Queck
Re: designate track for keyboard shortcut edit
on Apr 23, 2018 at 7:33:29 am
Activate Clip Skimming then it should work. Just hover over your clip with the mouse/trackpad.
You also can map Trim Start and Trim End to 'g' and 'h' without modifier, superfast...
