10.4.1 Caption fonts
Ben Lithman
on Apr 11, 2018 at 1:58:19 pm
Just a quick one. Any ideas how to change the font of captions in the new update to FCPX?
I must be doing something wrong... Right...??
Andreas Kiel
Re: 10.4.1 Caption fonts
on Apr 11, 2018 at 2:05:59 pm
I don't have the update installed, but per definition CEA-608 has no font option.
- Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Ben Lithman
on Apr 11, 2018 at 2:09:35 pm
Thanks Andreas, Same thing happens with ITTs
Andreas Kiel
on Apr 11, 2018 at 3:25:01 pm
I just a look the itt specs:
iTunes Timed Text Profile
Overview
This chapter specifies the iTunes Timed Text (iTT) file format for delivering timed text content to the iTunes Store. The iTT file format is a subset of the Timed Text Markup Language, Version 1.0 W3C Candidate Recommendation 23 February 2010 (TTML) (http://www.w3.org/TR/2010/CR-ttaf1-dfxp-20100223/) from the World Wide Web Consortium (W3C) (http://w3.org/). All iTT documents are TTML documents that use the restricted subset of TTML.
An iTT document specifies the font style, font color, text alignment, and layout of the timed text, as well as the text itself and the timing. The iTT format restricts what can be specified to make sure that the content is suitable for use as a subtitle track in iTunes Store content...
So no font here either.
- Andreas
Spherico
Andreas Kiel
on Apr 11, 2018 at 4:13:18 pm
Some addition to what I wrote.
Font can be defined as "Serif" or "Sans-Serif" on version 5.2 of itt.
- Andreas
Spherico
