Final Cut Pro X 10.4.1 now available on the App Store πŸŽ‰β€¦
Robin S. Kurz
on Apr 9, 2018 at 4:47:23 pm
https://itunes.apple.com/app/final-cut-pro/id424389933?mt=12
(MIN. macOS 10.13.2 REQUIRED!)
WHAT'S NEW:
Closed Captions
β€’ Import caption files into a Final Cut Pro project to automatically create time-synced, connected captions in the timeline
β€’ See captions directly in the Viewer
β€’ Use the Inspector to adjust text, color, onscreen location, and timing
β€’ Create captions in multiple languages and formats in the same timeline
β€’ Use the new Captions tab in the Timeline Index to search text, select captions, and quickly switch between different versions of your captions
β€’ Attach captions to audio or video clips in the timeline
β€’ Extract embedded captions from video to view and edit the captions directly in Final Cut Pro
β€’ Send your project to Compressor in a single step, making it easy to create a compliant iTunes Store package with audio and video files, captions, and subtitles
β€’ Validation indicator instantly warns about common errors including caption overlaps, incorrect characters, invalid formatting, and more
β€’ Embed captions in an exported video file or create a separate caption sidecar file
β€’ Share captioned videos directly to YouTube and Vimeo
β€’ Support for CEA-608 and iTT closed caption formats
ProRes RAW
β€’ Support for ProRes RAW files lets you import, edit, and grade using pristine RAW image data from the camera sensor
β€’ RAW image data provides ultimate flexibility when adjusting highlights and shadows β€” ideal for HDR workflows
β€’ Enjoy smooth playback and real-time editing on laptop and desktop Mac computers
β€’ Highly efficient encoding reduces the size of ProRes RAW files, allowing you to fit more footage on camera cards and storage drives
β€’ ProRes RAW preserves more of the original image data, making it an ideal format for archiving
β€’ Work natively with ProRes RAW or ProRes RAW HQ files created by ATOMOS recorders and DJI Inspire 2 drone
Enhanced export
β€’ The new Roles tab in the share pane displays title, video, and audio roles in a single, consolidated interface
β€’ Quickly view and choose roles to be included in exported video files
β€’ Roles settings and enabled/disabled states from the timeline are carried through to the share pane
β€’ Embed closed captions in a video file or export a separate captions sidecar file in CEA-608 and iTT formats
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training fΓΌr dich!
Youtube | Facebook
