How do I split audio from video in Final Cut Pro X?
Scott Allen
on Apr 3, 2018 at 3:41:54 pm
OK, maybe I should ask, "Is it possible for me to manually sync audio in Final Cut X - especially if the audio and video are already joined?"
I've been using Final Cut 7 for the last several years. I work at a film archive, where we scan archival film. Much of this film was shot in the earliest sound era by Fox Movietone cameramen. Single-system sound, with 11 frame separation between the image and the corresponding sound. Obviously, before 22 or 24 frame separation became the norm.
Whenever we scan a film that was shot this way, we have to pull the pic ahead by 11 frames. In Final Cut 7 this is very easy - just grab the picture track and pull it ahead. Or type in "11" and enter, and the track moves itself.
Enter Final Cut X and this is an unnatural act, an impossible dream, Apple knows best, blah, blah, blah. 8^) . I've tried a number of different ways and have searched online for a solution with no luck so far. Does anyone here have a suggestion?
Thank you in advance...
Scott Allen
Moving Image Research Collections
Univerity of South Carolina
Warren Eig
Re: How do I split audio from video in Final Cut Pro X?
on Apr 3, 2018 at 4:57:19 pm
Separate audio and video-- detach. Sync and then make compound clip?
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
Vimeo: https://vimeo.com/babyboompictures
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Jeff Kirkland
on Apr 3, 2018 at 6:28:03 pm
As above - or in the clip browser, select the clip, choose ‘open in timeline’ and move the audio as required?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Scott Allen
on Apr 3, 2018 at 8:46:54 pm
Great thanks to you both. I didn't know how to "detach" at first, but once I tried "open clip in browser", I was able to grab the sound and move it independently of the video. However, I could only move the audio forward - not move the video forward. So, I inserted a gap clip at the head, shortened it to the eleven seconds that I needed, and was then able to pull the audio back to the right spot.
It works now, though I wish there were a slightly easier way - but this isn't hard. Thank you both very much!
Scott Allen
Gregor Queck
on Apr 3, 2018 at 9:39:29 pm
"open clip in browser":
You can insert a gap at the beginning of the video clip (Alt-W?) and then move the sound 'backwards'.
Bret Williams
on Apr 4, 2018 at 9:00:23 pm
Wouldn’t it make more sense just to trim off the first 11 frames of the audio, then move it backward? You don’t need the 11 frames that don’t have visual most likely.
_______________________________________________________________________
http://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
Hang Tag http://bretfx.com/product/hang-tag
Overshoot Text http://bretfx.com/product/overshoot-text/
Outliner http://bretfx.com/product/outliner/
Clock Maker http://bretfx.com/product/bretfx-clock-maker/
