Consolidating several audio angles within a multicam sequence
Brian Thomas
on Mar 24, 2018 at 2:51:27 pm
Say I have just created a multicam clip with several camcorders and a whole lot of short audio clips. Each (non-overlapping) audio clip has been assigned it's own 'angle' so I'm having to page up and down to adjust volume etc.
How can I get all those small audio track easily onto one angle? I've tried pressing shift as I drag them onto the same angle and sometimes this works perfectly but other times they jump around a bit. Perhaps I shouldn't be using shift? Is there another key/combination I should be using to drag them into their equivalent position on one particular angle? Thanks in advance.
FCPX and PPro 6. iMac 24 + MBP 15". Near Geneva, Switzerland
Bill Rabkin
Re: Consolidating several audio angles within a multicam sequence
on Mar 26, 2018 at 2:41:01 am
Rather than dragging-and-dropping, you might want to try copy-and-paste. That should let you position the Playhead exactly where you want to "drop" the clip, and paste it right there.
Bill
FCPX 10.4
iMac 27" Retina 2017
macOS 10.12.6 Sierra
Brian Thomas
on Mar 26, 2018 at 5:43:35 am
Oh yes, thanks Bill, I'll try that.
