How to change the default audio fade curve
Lisa Johnson
on Mar 15, 2018 at 3:33:39 pm
I know, I know, I need to update my version of FCPX....
I am running 10.2.3. I would like to reset the default audio curve from +3 db to the S-curve. How in the world do you do this? Can you even do it? Can you do it in newer versions of FCPX?
Lisa 🙉
Jeremy Garchow
Re: How to change the default audio fade curve
on Mar 15, 2018 at 8:59:00 pm
Save the transition as a favorite and make it the default audio transition.
Doug Metz
on Mar 15, 2018 at 9:19:55 pm
I think Lisa wants to alter the default behavior of the audio handles themselves, instead of having to right-click and select the preferred curve.
Doug Metz
Anode
Jeremy Garchow
on Mar 15, 2018 at 11:44:46 pm
[Doug Metz] "I think Lisa wants to alter the default behavior of the audio handles themselves, instead of having to right-click and select the preferred curve."
Ah yes.
If true, that is something that would make a great feature request.
Lisa Johnson
on Mar 16, 2018 at 2:29:29 am
That’s exactly what I want to do!
Gregor Queck
on Jul 17, 2019 at 11:38:00 am
Have you found any solution?
”Conversations don’t have to be easy to be worthwhile”
Jordan Peterson
