Embedded captions
Oliver Peters
Embedded captions
on Mar 9, 2018 at 3:03:00 pm
Is there any way to pass through/edit/share video - either in FCPX or Compressor - and preserve embedded closed captions within the exported video?
- Oliver
Oliver Peters - oliverpeters.com
Jeremy Garchow
Re: Embedded captions
on Mar 9, 2018 at 11:52:38 pm
You can’t preserve them, but Compressor can add an scc file.
Oliver Peters
on Mar 9, 2018 at 11:56:54 pm
[Jeremy Garchow] "but Compressor can add an scc file"
Yes, I was able to test that, but the format options are limited. Thanks.
- Oliver
Andreas Kiel
on Mar 10, 2018 at 12:40:29 am
[Oliver Peters]... but the format options are limited.
What do you mean, what format options?
Anyway - Apple Codecs don't support embedded captions.
In theory Adobe/PPro does.
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Oliver Peters
on Mar 10, 2018 at 1:06:42 am
[Andreas Kiel] "What do you mean, what format options?"
You can only use .scc files. You can only add one caption file. So, for example, if I need both English and Spanish in one file, I can't do that.
[Andreas Kiel] "Anyway - Apple Codecs don't support embedded captions."
Hmm... I have ProRes files with two different embedded caption "tracks". I can use Telestream Switch to trim those files and re-encode (in video pass-though mode) new versions, which maintain the existing, embedded captions.
[Andreas Kiel] "In theory Adobe/PPro does."
You can add and edit captions in Premiere Pro and then export files with either "burned-in" (open) captions (subtitles) or with separate sidecar caption files.
- Oliver
Andreas Kiel
on Mar 10, 2018 at 5:06:54 pm
My bad - I wanted to write "Apple MXF codec" since I assumed you wanted to use embedded scc for broadcast.
Spherico
Oliver Peters
on Mar 10, 2018 at 6:18:26 pm
[Andreas Kiel] ""Apple MXF codec" since I assumed you wanted to use embedded scc for broadcast."
Not problem. However, in our case we had a master for broadcast on Univision (US Spanish language channel) and it was ProRes QuickTime with embedded English and Spanish closed captions. So MXF isn't a given here.
- Oliver
