Hard Drive Recommendation?
Michael Hadley
on Mar 7, 2018 at 11:13:13 pm
FCPX hive mind:
Looking for recommendation for a Thunderbolt 3 12-16tb external hard drive populated with 7200RPM drives. Looking for speedy read/write but want to as always be careful with my spend $.
Currently have TB2 Promise Pegasus drives, Cal Digit, and OWC drives but running out of space. Will be getting a new TB3 computer and want to know the best price/performance options you can recommend.
Primarily used for editing HD and 4K footage on FCPX.
Tim Jones
Re: Hard Drive Recommendation?
on Mar 8, 2018 at 4:09:18 am
Michael,
While it's a bit more expensive, by investing in a true SAS solution that is connected via TB adapter, you will have far more options moving forward. One good recommendation would be a combination of the Sonnet Tech SE-I Thunderbolt 3 to PCIe chassis. This allows you to install 2 PCIe HBAs. The result would give you the ability to add a true SAS HBA like the ATTO R680 or the HighPoint RocketRAID 4522 and later add a 10GbE network adapter.
You could then use anyone's SAS tower to hold and power your disks - we like the SANS Digital TR4X and TR8X units. These are cost effective, quiet, reliable (we have 2 that are over 8 years old), and can support any 3.5" SATA/SAS disk out there. You could load a TR4X with four 12TB and end up with 32TB of RAID-5 capacity. Here are some non-affiliate links so you can get an idea of the costs.
Sonnet Echo Express
https://www.sonnetstore.com/collections/thunderbolt-expansion-systems/produ...
SANS Digital 4 bay
https://www.amazon.com/Sans-Digital-TR4X-HA-TowerRaid/dp/B00JOCDC6Y/
ATTO R680
https://www.amazon.com/atto-technology-esas-r680-000-expsas-adapter/dp/B007...
HighPoint RR 4522
https://www.amazon.com/HighPoint-RocketRAID-4522-External-Hardware/dp/B009Y...
Seagate EXOS 12TB Enterprise grade disk
https://www.amazon.com/Seagate-Enterprise-Capacity-ST12000NM0007-7200RPM/dp...
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
