Optical Flow is just kickin' my a**
Brett Sherman
on Feb 22, 2018 at 7:56:49 pm
Pretty much every video I've made in the last couple months where at least one clip failed to render with Optical Flow. I can't use the "Flow" transition reliably anymore. Is everyone else having these problems?
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
Noah Kadner
Re: Optical Flow is just kickin' my a**
on Feb 22, 2018 at 8:50:59 pm
If it happens randomly/infrequently- not much to be done. If you see it consistently on the same clip that's something that could potentially be analyzed and fixed by Apple.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Brett Sherman
on Feb 23, 2018 at 1:17:57 am
For me its not infrequent at all. I don't know if things will get any better switching to High Sierra. But it's a continual problem. Given that optical flow is used for stabilization, speed changes and flow transitions, it's really become a workflow burden. And it's not super easy to figure out which clip is the problematic one besides stepping through one at a time.
Brett Sherman
Jeremy Garchow
on Feb 23, 2018 at 2:20:40 am
Have you tried making a new project and copying/pasting the old timeline in to it?
Sometimes deleting cache will help too.
Jeremy Garchow
on Feb 22, 2018 at 9:02:04 pm
Do you know which clip?
Sometimes, it's best to set act clip back to normal and remake the speed ramp.
