Audio compression filter - exist in FCP 10.4
Sam Lee
on Feb 21, 2018 at 4:54:26 pm
I could not find the basic audio compressor filter anywhere. Does FCP X even have this or I have to use other programs to compress the audio so that it evens out?
Their automatic magic wand is just not mature yet. It adds more noise and artifacts.
Gregor Queck
Re: Audio compression filter - exist in FCP 10.4
on Feb 21, 2018 at 7:06:17 pm
There are plenty in the Audio/Levels section of the Effects panel. I really like the Multipressor......
Jeff Kirkland
on Feb 21, 2018 at 10:21:02 pm
Fcpx has several compression options from basic compressors to complex multi-frequency versions. Under levels in the audio effects section.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Sam Lee
on Feb 23, 2018 at 2:06:50 pm
Thanks. Found it. Also, I'm curious to know where can I find a basic hum remover filter from noisy XLR mics? It's not obvious and could it be under a different filter name?
