iMac Pro adaptor to HDMI as second monitor?
Craig Seeman
on Feb 2, 2018 at 10:19:06 pm
Attempting to add second monitor to my setup (Dell U2713hm or HP L2745w) via HDMI.
I attempted to use TB3/USB-C to HDMI cable known compatible with new MBP but it does not work with iMac Pro.
Computer doesn't acknowledge anything is connected.
B&H recommended this which did not work
http://ezq.com/usb-c-hdmi-cable-60hz-2m.html
I posted on Apple's Community Forum and the only recommendation was Apple's
USB-C Digital AV Multiport Adapter
https://www.apple.com/shop/product/MJ1K2AM/A/usb-c-digital-av-multiport-ada...
Which is not all that great given it's limited to 30Hz at 4K.
Seems others are having issues finding a viable solution.
https://discussions.apple.com/thread/8262750
So perhaps there's a serious compatibility issue.
Can anyone CONFIRM a TB3/USB-C to HDMI solution that is 60Hz?
Craig Seeman
Re: iMac Pro adaptor to HDMI as second monitor?
on Feb 5, 2018 at 10:30:56 pm
Apparently I'm alone in this or everyone is using Display Port to USB-C.
In any case I found I had to reverse the cable and push very hard to snap in.
This is not something I needed to do using my Apple TB3 cable which doesn't seem to "lock" like the USB-C cable does. It might just be the specific manufacture's cable.
