Wiggly/Distorted Video in Slow Mo Portions of Export from FCX
Elliot Bendis
on Jan 22, 2018 at 9:25:22 pm
I've troubleshooted, deinterlaced, etc. This is footage from maybe five years ago, so I don't have camera settings easily available.
Everything looks fine when I export, save for when there are any slow motion sequences. Those sequences have the famous squiggly lines running through them. Any pointers?
Have test exported with Field Dominance Override set to OFF and the Deinterlace option CHECKED.
P.S. Just checked that the actual clips that distort when exporting have a different frame rate. Is there a way to change individual clip's frame rate?
Settings
1920 x 1080. 29.97i
Oliver Peters
Re: Wiggly/Distorted Video in Slow Mo Portions of Export from FCX
on Jan 22, 2018 at 11:30:44 pm
Are you processing your slow motion with optical flow?
- Oliver
Oliver Peters - oliverpeters.com
Elliot Bendis
on Jan 23, 2018 at 4:11:16 am
I JUST started doing that after researching some more. Gonna do a test export right now.
Elliot Bendis
on Jan 23, 2018 at 5:46:21 pm
No luck. Same problem but it's not as bad. Any other suggestions? Much appreciated.
Oliver Peters
on Jan 23, 2018 at 6:10:40 pm
Your description really sounds like something that's interlaced, but has been incorrectly resized or deinterlaced upstream.
- Oliver
Oliver Peters
on Jan 23, 2018 at 6:15:30 pm
Originally you said this was 1080i/29.97. I presume you mean both the project (sequence) setting and the original source media. This should be Upper Field dominant. Are you able to view this through a real broadcast i/o device to an actual broadcast monitor? If so, without any manipulation, when you put a clip into the sequence, does it look normal on your display when playing it back?
- Oliver
Elliot Bendis
on Jan 24, 2018 at 12:57:03 am
Thanks for your help. Figured it out. A simple switch to "29.97p" instead of "i" solved it.
