Determining the plugin effect
Greg Ball
on Jan 16, 2018 at 2:47:13 pm
My hard drive crashed, and I had to start from scratch. My projects load fine, but I can't figure out what effects were used in the timeline. All I get is the red box with the yellow triangle and exclamation point. Is there a way I can identify the effect so I can download it? Thanks for your help.
Greg Ball, President
Ball Media Innovations, Inc.
https://www.ballmediainnovations.com
Michael Hancock
Re: Determining the plugin effect
on Jan 16, 2018 at 2:49:26 pm
Is the effect not listed in the Inspector when you select a clip?
EDIT: You could download X-FX Handler. Export an XML of your sequence and import that into X-FX Handler and see if it lists all the effects you used.
http://www.spherico.com/filmtools/X-Files/X-FXHandler/
Michael Hancock
Editor
