XDCAM Disc and High Sierra import?
Don Smith
on Dec 15, 2017 at 12:37:01 pm
Are you importing physical XDCAM discs using High Sierra?
Before I upgrade my company Mac to High Sierra and the newest Final Cut Pro X, I need to make sure that the driver for recognizing the drive with the XDCAM disc mounted is recognized. I know the other drivers aren't working but now that FCPX will import the media from the physical XDCAM disc as long as High Sierra can 'see' the XDCAM disc and mount it, I need to make sure that the driver for the XDCAM disc drive works under High Sierra.
Noah Kadner
Re: XDCAM Disc and High Sierra import?
on Dec 15, 2017 at 3:20:59 pm
My suggestion would be test on a single machine so you confirm the specifics of your workflow. My suspicion is that it's unlikely that XDCAM discs are being used much anymore and there not thoroughly tested in HS- but I could be wrong.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
MUKI PICTURES
on Feb 5, 2018 at 6:58:31 pm
Greetings.
I am running up against the same questions and wonder if by now you have found the answer about High Sierra's compatibility. I was OK with El Capitan but have had to buy a new laptop for the road -which has Sierra installed.
Thank you for sharing what you have found!
Kimu
MUKI PICTURES LLC
Don Smith
on Feb 5, 2018 at 9:19:56 pm
I'm monitoring the Japanese site to see when Sony will update its XDCAM driver. v5.0.8 is not High Sierra compatible. When the number increments higher, then it's likely ready for High Sierra.
https://www.sony.jp/xdcam/support/download/drive_software_download.html
NewsVideo.com
Don Smith
on Feb 21, 2018 at 9:16:59 pm
The driver for Sony XDCAM supporting Mac OS X High Sierra is out on Sony's Japanese page here:
NewsVideo.com
MUKI PICTURES
on Feb 21, 2018 at 9:58:52 pm
Thank You Don! This is great news!
Kimu
MUKI PICTURES LLC
