Compressor/FCPX timecodes not matching
Lisha Rigney
on Dec 13, 2017 at 8:41:54 pm
Hello to all,
I am creating a video reference file for a Pro Tools audio mix session. I sent a file to Compressor 4.3 from FCPX 10.3.1. I generated a visual timecode in Compressor but the timecodes are not matching. Any idea what is causing this? The project is drop frame.
https://drive.google.com/open?id=1F91drPRFJYfB6EF1Hqrl_Ps7QP6rO8_t
Thank you in advance for any assistance,
Lisha
Ryan Ritchey
Re: Compressor/FCPX timecodes not matching
on Dec 18, 2017 at 4:54:51 am
Hi Lisha,
I'm having a similar problem. What frame rate are you using? And are you on high Sierra by any chance? I'm having this issue both in FCP X and Premiere, which makes me think something might be going on at the system level in high sierra.
Lisha Rigney
on Dec 21, 2017 at 8:44:10 pm
Hi Ryan,
I'm still using El Capitan. Plan on updating once I've finished the batch of shows I'm currently editing. I ended up generating the TC in FCPX, exporting a Quicktime video and then sending to Compressor to make the file small enough for the Pro Tools session.
Lisha
