adjustment layer LUT bypass
Von Jackson
on Dec 11, 2017 at 7:46:00 am
Hey guys. I'm new to the forum. I'm using FCPX 10.3. I have an adjustment layer with a LUT over all my clips but everytime I go to tweak the colors/exposure on my clips the adjustment layer gets selected & tweaked instead. is there a way I can bypass the still visible LUT layer and tweak the clips under without having to manually click each one?
Noah Kadner
Re: adjustment layer LUT bypass
on Dec 11, 2017 at 1:37:38 pm
Color board is per clip/not global, so you need to select individually.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeff Kirkland
on Dec 12, 2017 at 6:56:49 am
pressing 'C' should select the clip on the primary storyline that's under the playhead.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Noah Kadner
on Dec 12, 2017 at 8:14:46 am
Right which in this case will be the "adjustment" layer, which I personally am not a fan of because it's not something FCPX itself is aware of.
Noah
Von Jackson
on Dec 12, 2017 at 6:47:39 pm
correct. I'm trying to avoid pressing any keys & auto select the under clips as if the layer didn't exist. Maybe there will be an option in 10.4
Jeremy Garchow
on Dec 13, 2017 at 3:19:03 am
Map a key to “select below”.
I know you want to not press anything and have FCPX know which layer in the stack you want to adjust, but that’s a tall order.
Jeff Kirkland
on Dec 14, 2017 at 6:45:09 pm
10.4 now has roles based clip selection. You can use the arrow keys to select the next/previous clip based on its role wherever it may be in the stack.
