MacBook Air shut down and FCPX Event is empty
McKenzie Ryan
on Dec 4, 2017 at 7:34:31 pm
My MacBook Air shut down and when I reopened FCPX my event had turned into a weird folder thing, the event logo is gone and empty. All of my footage I had been making into compound clips have also disappeared.
I tried a thread on here that had me make a new event in FCPX and then close the application. I then went into the libraries packaged contents in which I copied and moved everything from the old broken event to the new one. I then re-opened FCPX and the new event is now also broken (missing the event logo, etc.)
This is what the events now look like:
Any help is highly appreciated,
Thank you.
Specs:
MacBook Air mid-2011
FCPX Version 10.2.3
Noah Kadner
Re: MacBook Air shut down and FCPX Event is empty
on Dec 4, 2017 at 8:18:58 pm
I advise strongly against ever mucking around in the file folder structure for FCPX.
https://support.apple.com/kb/PH15847?locale=en_US
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
McKenzie Ryan
on Dec 4, 2017 at 8:46:01 pm
Thank you for the response. The initial and remaining problem did not occur from my work inside the packaged contents, but instead because my laptop shut down while in FCPX. I will be sure to try out the link you sent me.
Thank you for your time.
Jeff Kirkland
on Dec 6, 2017 at 6:00:31 pm
what about restoring the auto backup File?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
McKenzie Ryan
on Dec 7, 2017 at 4:17:36 pm
At first, I tried this and got it back, but yesterday my laptop once again completely shut down while in FCPX. When I returned there wasn't even a backup for all of my work I did for over an hour.
I'm not sure what I can do at this point. The event I was working on, and the ones that were broken, have completely disappeared from the sidebar, yet are folders in the Packaged Contents.
