issius with luts
Vegdo Rjabkov
issius with luts
on Nov 26, 2017 at 2:25:50 am
Hello,
i am making a music video. i extracted out of the clips the pictures of the different scenes. i am using lightroom 6 for creating the luts.
My problem is that, my edited picture in lightroom looks nice but the lut that i puted on the same clip looks much darker and different.
for me it makes no sense that i create my clip in lightroom and when i am using the lut for the scene that it looks complete different.
i will put a picture of my lightroom and than a picture how it looks in fcpx.
i really dont know what to do and i am very thankfull for any help.
Jeremy Garchow
Re: issius with luts
on Nov 26, 2017 at 4:28:58 pm
How are you exporting the LUTs out of Lightroom and what kinda of adjustments are you making?
Vegdo Rjabkov
on Nov 26, 2017 at 4:54:50 pm
I am exporting with John R. Ellis and I also tried with Lut generator.
i also switcht to 3 diffrent lut import programs in fcpx.
i am only changing the basic, tone curve, hsl and splittoning. the rest is disabeled.
i also tried diffrent colormodes, but only smal changes.
In 5 days i have to buy fcpx, till now i am using the trial, but there should be no problem or ?
Jeremy Garchow
on Nov 26, 2017 at 5:02:19 pm
Not all settings translate to a LUT. Not sure what splittoning is, maybe that’s it?
Do you have any other “Log Processing” enabled in FCPX?
Vegdo Rjabkov
on Nov 26, 2017 at 6:29:31 pm
i also turned off the highlights. no i dont run any other log processing
Jeremy Garchow
on Nov 26, 2017 at 8:13:25 pm
What color space is the original footage?
Have you double checked the color space override or log processing settings in the inspector?
Vegdo Rjabkov
on Nov 27, 2017 at 4:29:52 pm
the color space in the original footage was sRGB.
what is ''Have you double checked the color space override or log processing settings in the inspector?''
what can i check, i dont now what this is
Jeremy Garchow
on Nov 27, 2017 at 4:54:49 pm
Open the inspector, client the "info" button, choose "Settings" from the dropdown and look at what the settings are.
Here's a picture:
Vegdo Rjabkov
on Nov 27, 2017 at 5:00:11 pm
no, both are disabled.
didnt know what you mean, my fcpx is in german 😃 thanks for the pic
Vegdo Rjabkov
on Nov 27, 2017 at 5:02:21 pm
here a 2 more pics. i completely overexposed the lut in lightroom and see the reslut in fcpx
Jeremy Garchow
on Nov 27, 2017 at 5:08:20 pm
I assume the bottom one is Lightroom? Which is which?
Vegdo Rjabkov
on Nov 27, 2017 at 5:15:04 pm
the bottom one is lightroom
Jeremy Garchow
on Nov 27, 2017 at 5:29:03 pm
OK. So it looks like the LUT isn't working in FCPX at all.
Can you please show a picture of the inspector with the LUT effect applied and turned on?
Vegdo Rjabkov
on Nov 27, 2017 at 5:56:22 pm
Vegdo Rjabkov
on Nov 27, 2017 at 5:58:20 pm
Jeremy Garchow
on Nov 27, 2017 at 6:14:56 pm
What happens if you completely reset the LUT effect, and ad the LUT? It looks like you have some settings there that may be reducing the effect of the LUT.
Also, you would have to go through every step of the Lightroom exporting process.
There is some setting somewhere that is not getting translated or included.
Vegdo Rjabkov
on Nov 27, 2017 at 6:34:30 pm
i dont know if i undertood you right, i went to lighroom and reseted all settings and crated out of this a lut and aadded to fcpx.
but now changes
Vegdo Rjabkov
on Nov 27, 2017 at 7:12:18 pm
I tried to create a lut on the lightroom cc on the windows pc of my brother. Here a the two luts results in fcpx
Lightroom 6 on my mac
Lightroom CC used on the windows pc of my brother
Vegdo Rjabkov
on Nov 27, 2017 at 7:18:54 pm
ofcurse i used in lightroom cc and 6 the same settings..
Vegdo Rjabkov
on Nov 27, 2017 at 6:00:21 pm
this is how its looks in fcpx with and without the lut.
and the third picture is of the inspector
Geoff Addis
on Nov 27, 2017 at 7:28:02 pm
What is the format of your photo in Lightroom? If it is RAW, then convert it to JPEG orTIFF and then apply correction to that before exporting a LUT.
Vegdo Rjabkov
on Nov 27, 2017 at 8:00:33 pm
it is a .tiff that i took out of the video
Vegdo Rjabkov
on Nov 27, 2017 at 8:17:30 pm
Now i am speachless....
I i used the lut that was created with my Lightroom 6 (used on Mac)
and i used the lut that was created with Lightroom CC 2017 from the Windows PC of my brother
both luts extraced with john r. ellis lut loader.
now when i am using both of them i get the same result as in Lightroom........
here the image to compare exported out of my lightroom 6
Jeremy Garchow
on Nov 28, 2017 at 3:02:23 am
So the Lightroom 6 LUTs do not work, but Lightroom CC LUTs work?
Vegdo Rjabkov
on Nov 28, 2017 at 5:29:38 am
NO, the CC lut looks diffrent to the Lightroom 6 lut. but wehen i use them together i get the same reslut.
now i installed lighroom cc 2017 also on my mac and all 3 luts looks diffrent ...
Jeremy Garchow
on Nov 28, 2017 at 4:44:38 pm
[Vegdo Rjabkov] "now i installed lighroom cc 2017 also on my mac and all 3 luts looks diffrent ...
It is hard to diagnose the problem as it seems that at some point, you have two LUTs on, and others, you have settings enabled in the LUT filter that will alter the look of the LUT ("Intensity" etc).
Is it possible to upload the original TIFF and LUT so I can see what it looks like here?
Vegdo Rjabkov
on Nov 28, 2017 at 8:53:58 pm
i cant upload the .tiff it is bigger than 50mb
here is the lut that i generated in lightroom, how i want the video to look like:
11912_lutforcreativcow.cube.zip
Vegdo Rjabkov
on Nov 28, 2017 at 8:58:13 pm
here you can download via rapidshare:
http://www.rapidshare.com.cn/WC2EVP5
and here is the picture how it should look like:
Jeremy Garchow
on Nov 28, 2017 at 11:20:19 pm
Sorry, can you also export your LR settings as a preset?
Vegdo Rjabkov
on Nov 29, 2017 at 3:45:21 pm
here it is
11913_creativcow.lrtemplate.zip
Jeremy Garchow
on Nov 29, 2017 at 4:43:40 pm
Thanks so much this helps.
When I go to export a LUT, it says that there are certain settings that won't be transferred to the LUT, which is why you aren't getting the expected result in FCPX.
See here:
If you turn those two parameters off, and use the Tone Curve to get a similar look, you will get a direct LUT transfer from Lightroom.
Vegdo Rjabkov
on Nov 29, 2017 at 6:48:18 pm
thanks alot 😃 but why they dont transfer the highlights and the shadows into the lut ?
Jeremy Garchow
on Nov 29, 2017 at 7:15:46 pm
[Vegdo Rjabkov] "thanks alot 😃 but why they dont transfer the highlights and the shadows into the lut ?"
It must be the way the data is expressed in the "Basic" section and what can be achieved in a point based LUT.
The "Tone Map" area has similar controls, and are probably easily mapped to a plot.
You should contact the LUT exporter developer and see if they have any insight.
LUTs are not definitive. They are usually a starting point to get footage within the realm of the same look between on set, edit, final grade, and output. Most of the time, they carry grade intention, more so than grade instruction.
Vegdo Rjabkov
on Nov 30, 2017 at 5:25:15 am
ok, thanks alot fpr your help :)!!!
Jeremy Garchow
on Nov 30, 2017 at 1:03:58 pm
No problem.
Thanks for sending over all the materials. It helps to be able to see what is going wrong exactly.
