VHS Rewind Glitch Effect
Murtaza Aziz
on Nov 22, 2017 at 7:37:21 am
Hi everyone,
Is it possible to do this below vhs rewind effect in Final cut pro x please. I have tried to check on google but cannot find any tutorials on how to achieve a similar effect.
Thank you.
Paul Golden
Re: VHS Rewind Glitch Effect
on Nov 22, 2017 at 5:14:12 pm
Try the effect Bad TV, which is part of your installed effects with FCPX.
Murtaza Aziz
on Nov 22, 2017 at 7:46:46 pm
Thank you Paul. I tried the Bad TV. It is close. Was trying to figure out how to get those vhs lines also like in the example. Thanks for your reply. Will look more into it.
Murtaza Aziz
on Nov 22, 2017 at 10:26:16 pm
Thank you Noah for the video. Will check it out.
