Working with slo motion footage
David Mayer
on Nov 15, 2017 at 11:42:45 pm
I shot super slo motion with my Sony FS5. 240 fps. Should be 8 times slower than live action. In Final Cut it is 4 times slower. Is there an operation in Final Cut to stretch it out to its full value? (Slowing it down does not work - just doubles some of the frames and degrades the quality.)
iMac (Retina 5K, 27 inch, Late 2015)
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.12.5
Final Cut Pro X (10.2.3)
Canon C100
Sony FS-5
Pioneer BD-RW BDR-206D (Blu-ray)
Jeremy Garchow
Re: Working with slo motion footage
on Nov 16, 2017 at 5:23:12 pm
[David Mayer] "Should be 8 times slower than live action. "
What frame rate is your timeline?
I assume you are working in a 29.97 timeline. Did you shoot at 29.97 in your camera? Meaning, I know you shot at 240, but the camera stamps the footage with a frame rate. What is it?
Noah Kadner
on Nov 16, 2017 at 8:35:19 pm
Believe you can set the timebase as metadata in the F55- it's possible that isn't being read by FCPX. If it's not, feel free to adjust with retiming.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeremy Garchow
on Nov 16, 2017 at 9:10:50 pm
[Noah Kadner] "Believe you can set the timebase as metadata in the F55"
Yes, the system frequency is set at either ~24, 25, ~30, 50 or ~60.
So 240fps can be 10 times as slow, or 4 times as slow as the timeline speed if the camera system frequency and timeline fps match.
And if the system frequency is set to something other than the FCPX timeline fps, then you will get double frames, as David says.
You are essentially playing 24fps footage in a 30fps timeline, or some combination therein.
The "Automatic Speed" command should solve this, automatically adjusting the relative clip speed to the timeline fps, resulting in 1:1 playback.
