looking for a plugin to give still photos a handheld camera look - slight movement not real shaky
Larry Watts
on Nov 14, 2017 at 4:12:29 pm
I am looking for a plugin to use on still images to give them a handheld camera look. Any recommendations?
Jeremy Garchow
Re: looking for a plugin to give still photos a handheld camera look - slight movement not real shaky
on Nov 14, 2017 at 4:58:14 pm
"Handheld" in FCPX?
It's in the "Stylize" group
Mark Suszko
on Nov 14, 2017 at 5:33:17 pm
You can also DIY the effect by aiming a real hand-held camera at a dot on a plain surface, motion-tracking the dot, and applying that motion track to the target video. Somebody, I forget the company, sells exactly that, pre-made for you. It might be Rampant or MotionVFX.com or some other.
Anton Antokhin
on Nov 15, 2017 at 5:11:52 am
CineFlare HandHeld is really good. The suite has Drift and Hand Held plugins, each with a ton of presets. Also a couple of simulated swish pan transitions.
