Render Optical Flow
Thanos Papadopoulos
Render Optical Flow
on Oct 16, 2017 at 6:47:23 pm
Is it only me having problems when I need to render clips with speed segments and optical flow (video quality)?
This thing happens often with different clips and on different macs. These clips cannot be rendered! I have to export it and reimport it to see these clips. Is it a bag?
Fix it in Pre.
Noah Kadner
Re: Render Optical Flow
on Oct 16, 2017 at 8:09:08 pm
Anything's possible with the right combination of source media and system specs but as a general workflow- working fine here.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeff Kirkland
on Oct 16, 2017 at 8:59:43 pm
It's just you. Optical flow is working as expected on the three macs in my office.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Thanos Papadopoulos
on Oct 16, 2017 at 9:18:18 pm
Optical flow with 2 or 3 speed segments renders normally?
Fix it in Pre.
Noah Kadner
on Oct 16, 2017 at 9:22:48 pm
No issues here. However if you can make it happen consistently-
http://www.fcpworks.com/submitting-better-fcpx-feedback-to-apple/
Noah
Joe Marler
on Oct 17, 2017 at 12:28:43 am
[Thanos Papadopoulos] "This thing happens often with different clips and on different macs. These clips cannot be rendered! I have to export it and reimport it to see these clips"
I have seen this behavior periodically, and I've seen others report it. I think it's a bug. However you don't need to export and re-import it. The optical flow is usually being calculated correctly upon export, but it doesn't always render visually properly in the timeline.
I've seen reports that deleting generated library files might make the problem temporarily go away. Also if you are using optical flow on a speed ramped clip that can cause it. In that case try blading the clip and only apply optical flow on the bladed section.
Thanos Papadopoulos
on Oct 17, 2017 at 4:13:44 am
Thanks Joe.
Fix it in Pre.
Jeremy Garchow
on Oct 17, 2017 at 6:41:36 pm
I also think Optical flow cause weirdness if the clip and timelknenframe rate mismatch (30p clip in 24p timeline, or similar).
Not sure if it applies to you, but other than that, I find optical flow to work really well most of the time, depending on what I’m trying to slow down.
Thanos Papadopoulos
on Oct 17, 2017 at 8:22:07 pm
I use optical flow really often and helps me a lot too. I don't think that is a frame rate issue but I'll check this out next time and I'll update this thread.
I am a freelancer editor so I use different editing suits and I'll confirm if it's a hardware or software problem.
Fix it in Pre.
Doug Metz
on Oct 17, 2017 at 10:31:14 pm
I also use it regularly, and can corroborate Joe's findings. Had this problem last week on a 30p animation (matching timeline frame rate). Timeline showed unrendered optical flow sections but was able to output successfully.
Doug Metz
Anode
Nikos Papadopoulos
on Oct 30, 2017 at 12:51:34 pm
Usually this happens if the system has NVIDIA instead of AMD. If you're on a Mac Pro (pre 2013) and have installed a custom NVIDIA card, know that this is usually the cause. If you're on a laptop with NVIDIA, again its a bug. After working on the latest MBPro 2017, all these issues disappeared for me.
Passion and knowledge put to work
nick314.com
Thanos Papadopoulos
on Oct 30, 2017 at 12:59:54 pm
Thanks I'll check it. Although I have seen this to 2 mac pro (one 2013 and one older) and one Imac 2014. But I'll check the graphic cards.
Fix it in Pre.
Joe Marler
on Oct 30, 2017 at 9:16:34 pm
[Nikos Papadopoulos] "Usually this happens if the system has NVIDIA instead of AMD"
I have four Macs with AMD GPUs and I periodically see this problem on all of them. As soon as 10.4 is released I'll test that.
Bruno Courcet
on Apr 23, 2018 at 1:52:17 pm
Same issue here. Sometimes it just won't render. I have to chose frame blending or normal to have it rendered.
I've managed to improve it by always waiting till optical flow has completely finished being calculated before rendering. Then i'm able to render. But sometimes if i close the project and re-open it another day some clips with optical flow are not rendered and won't get rendered, except if i choose frame blending or normal.
Tommy Brown
on Oct 12, 2018 at 12:19:55 pm
Hi Thanos
So this issue really bugged me a while back and after lots of searching I final found the answer that has been working for me ever since.
When choosing Optical Flow let it FINISH its analysis before moving on. On export yes it will be fine but in the projects I can now render all my Optical Flow clips.
Hope it helps.
Thanos Papadopoulos
on Oct 12, 2018 at 12:22:39 pm
I'll try your suggestion.
Fix it in Pre.
Eric Santiago
on Oct 12, 2018 at 2:05:26 pm
Just to add, I had a few posts here about this issue.
Only to find that a client used the Flow transition which would not render period.
Once I removed the transitions, the project wasn't crashing and using Optical Flow with clips were a breeze.
And yes, always let it render first before doing anything.
Learned that the hard way :P
Jeremy Garchow
on Oct 12, 2018 at 3:09:35 pm
To add to the add, there are other processes that use optical flow like stabilization. Be sure to check if any clips have that turned on.
Sometimes you have to re add the clip to the timeline to shake loose the failed processing, but this is a rare occurence.
Eric Santiago
on Oct 12, 2018 at 3:32:06 pm
[Jeremy Garchow] "Sometimes you have to re add the clip to the timeline to shake loose the failed processing, but this is a rare occurence."
So true. I was one of those that gave up on any digital voodoo e.g. stabilizer, optical flow, etc.. in FCPX but after that long bout of hell, it's been a slice of late.
Mind you I still can crash FCPX with the simplest editing of titles but it's not as bad as other NLEs when it comes to crashing.
FCPX remembers most of your work at least ;)
