Workflow Advice
Scott Witthaus
Workflow Advice
on Oct 16, 2017 at 11:19:10 am
Client of mine is taking some basic timelines from FCPX to be finished in NYC on an Avid system. What is the best workflow for that? Thanks in advance.
Scott
Scott Witthaus
Owner, 1708 Inc./Editorial
Managing Partner, Low Country Creative LLC
Professor, VCU Brandcenter
Oliver Peters
Re: Workflow Advice
on Oct 16, 2017 at 12:51:04 pm
Depends on the source media. Do you have valid TC and unique file names on all clips? The easiest free solution might be to wash it through Resolve. Or maybe use Automatic Duck (FxFactory), but that probably means FCPX to AE to Premiere to AAF.
Or, just export a flattened timeline with some handles. Of course, then you lose your links to the source media, but it still might be the best solution if the others don't work.
- Oliver
Oliver Peters - oliverpeters.com
Eric Santiago
Re: Workflow Advice
on Oct 17, 2017 at 4:23:42 am
I had great luck with using Resolve to Avid from an FCPXML file.
But I've only done this with RED files.
