Final Cut Pro X 10.34
Dawson Bliss
on Oct 11, 2017 at 1:11:20 am
I am starting a new project in FCPX and load 40 GB of files. Soon after that I run out of room on my HD and see that it has loaded my HD with a folder (Untitled) with 99.65 GB ..... Does anyone know what is happening. The settings on FCPX is set to leave files in place. Thanks in advance for any help. Dawson https://www.youtube.com/user/chebliss/videos
Jeremy Garchow
Re: Final Cut Pro X 10.34
on Oct 11, 2017 at 3:18:22 am
Do you have “create optimized media” checked?
Dawson Bliss
on Oct 11, 2017 at 3:20:31 am
No I did not ....?
Jeremy Garchow
on Oct 11, 2017 at 3:22:06 am
What kind of media are importing?
Are you making multicam clips?
Dawson Bliss
on Oct 11, 2017 at 3:29:43 am
I did not have Create Optimize Media ticked but I am importing single cam .mov files.
Jeremy Garchow
on Oct 11, 2017 at 3:36:18 am
Can you show screengrabs of the Untitled folder?
Dawson Bliss
on Oct 11, 2017 at 3:47:19 am
After ticking optimised media and deleting all files and then re importing the same folder of files , some 40 Gb the 'UNTITLED FOLDER ' had under a GB in it but now its up to 98GB and I have done nothing with the Project but its up to 98 GB in an hour or so ... not sure how to post Screen Grab onto here?
Jeremy Garchow
on Oct 11, 2017 at 3:53:03 am
Drag the picture in to the text box.
Dawson Bliss
on Oct 11, 2017 at 3:54:30 am
Did that but dragged the wrong file in ... arghhh ... here it is now
Jeremy Garchow
on Oct 11, 2017 at 3:54:02 am
[Dawson Bliss] "After ticking optimised media "
So you are creating optimized media?
If so, that’s probably your problem.
Dawson Bliss
on Oct 11, 2017 at 3:56:45 am
No I wasn't and someone suggested to tick that box and the problem continues after deleting the files starting a new project and importing the same original 40 GB folder ... the untitled folder reappeared and is 90 GB
Dawson Bliss
on Oct 11, 2017 at 4:03:43 am
Now the untitled folder has increased to 117 GB and I have not been working on the Project
Jeremy Garchow
on Oct 11, 2017 at 4:09:21 am
Ok, that’s a library, not a folder.
My guess is that background rendering is on, final cut is rendering your timeline, and your render cache is in the library, making it larger.
Dawson Bliss
on Oct 11, 2017 at 4:15:17 am
Ok changed that & it looks like that was the problem, but where else and how can I put Render files onto say an external HD.
Jeremy Garchow
on Oct 11, 2017 at 11:00:32 am
[Dawson Bliss] "Ok changed that & it looks like that was the problem, but where else and how can I put Render files onto say an external HD.
You have to modify the cache settings in fcpx.
Select the Library in the FCPX Browser and Open the inspector. You will see a button
to modify cache position.
Jeremy Garchow
on Oct 11, 2017 at 11:03:47 am
Here’s a guide: https://support.apple.com/kb/PH17905?locale=en_US&viewlocale=en_US
Dawson Bliss
on Oct 11, 2017 at 5:07:00 am
Not sure what happened but now there is a hidden file somewhere that has taken over 100Gb and it can only be from FCPX ... any suggestions
Eric Santiago
on Oct 11, 2017 at 6:27:43 pm
From 2011 till today, whenever a strange file/folder shows up in my system due to ingest from FCPX, I just toss it out.
I rarely use Optimized/Proxies and always use Leave files in place.
However, some odd formats tend to make FCPX act oddly.
I was strictly RED eco for years until this year.
Started getting projects from different cameras.
Patrick Donegan
on Oct 21, 2017 at 3:58:12 am
When I have trouble finding large files or folders I use
OmniDiskSweeper to be able to see all the folders in order of size.
Very smart for video files.
FCP X 10.2.3 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
iPhone 4
HVX-200, Shure wireless mic
Miller Solo tripod
Advanta-Jib
