FCPX Will Not Open After Pixel Film Studios Plugin Install
Greg Ondera
on Sep 14, 2017 at 7:39:32 am
I may as well give these details first:
Mac Pro Early 2008
OS 10.11.6 El Capitan
2x 3.2 Quad-Core
32 GB 800 MHz DDR2 FB-DIMM
So to start off, I am told not to upgrade the OS on this early 2008 Mac Pro anymore. The machine won't handle it.
I purchased two Pixel Film Studios plugins using the auto-tracker feature, not realizing these required OS Sierra and above. I had purchase plugins before from them, but this time, something weird was going on with the install even before I tried opening FCP. the install window stalled and froze. I had to reboot.
Now I don't want to bore you with all the tedious details, but to make a long story short, I cannot open FCP now at all. I have a client breathing down my neck and I have already lost two days of editing because of this.
I uninstalled the plugins, I cleaned out FCP Preferences. I opened successfully FCP holding down the option key and once succeeded at creating a new Library. But in no instances, even going back to historic Libraries that I knew were uncorrupted could I open any Libraries at all.
I shut the computer down overnight, then booted it up and now I can't even get into FCP at all, even with the option key. As well I cannot open any Library.
I did contact Pixel and I am awaiting to hear if they can tell me something more informative but it is taking them a while. They did tell me to uninstall and that Auto-tracker is the problem, but they haven't gotten back to me yet on how to get FCP open.
Help! Any ideas? I will be endlessly grateful to anyone who has insight into this problem.
Greg Ondera
Plexus.tv
Surgical Video Production Coast to Coast
Jeff Kirkland
Re: FCPX Will Not Open After Pixel Film Studios Plugin Install
on Sep 14, 2017 at 9:07:51 am
You've done pretty much everything I'd suggest - except delete and reinstall FCPX.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Craig Seeman
on Sep 14, 2017 at 12:35:21 pm
Create a New User Admin account. Make sure there are no Login items (things that run as soon as you log in). Reboot the computer and log in to the new user account and then open FCPX.
Greg Ondera
on Sep 14, 2017 at 3:23:35 pm
Thanks for this. I'm afraid I am now out the door for 10 days and will have to attempt these remedies when I return.
Greg Ondera
Plexus.tv
bob guerrero
on Jan 15, 2018 at 12:19:13 am
Greg - I have the same setup as you and trying to get Pixel Film Studios - Pro6 to work. Did you find a solution?
Greg Ondera
on Jan 15, 2018 at 7:34:50 am
The problem was resolved somewhat. I had to reinstall FCPX entirely, however after reinstalling it, not all of the Motion items, such as colored backgrounds were downloaded with FCP. I attempted to install those separately, but did not have success at that. I have been busy enough that I have used work-arounds, creating my own backgrounds in Photoshop and that, and not have had time to really try to fix FCP. Another oddity that is happening is that when I turn on my computer, FCPX will not start up until after about 15 minutes. Likewise with iTunes for some reason. I have initiated moving over to Premier but must admit that I came to really like FCP when it worked fully.
Greg Ondera
Plexus.tv
