Gap between clips when copy paste from one project to another
Thanos Papadopoulos
on Sep 13, 2017 at 10:43:51 pm
I duplicated my project and I needed to do a copy paste from my previous project. Then I noticed a gap between my clips. Also some audio clips have lost synch because the connection of the audio clip with the primary story line has moved to the gap.
I tried for a sideway to do it. I selected some clips and created a compound clip. I double clicked the compound and I saw that the clips also had a gap between them.
Are there any thoughts?
Fix it in Pre.
Jeremy Garchow
Re: Gap between clips when copy paste from one project to another
on Sep 14, 2017 at 3:37:46 am
The Projects have different frame rates?
Thanos Papadopoulos
on Sep 14, 2017 at 5:57:25 am
I checked project settings and its the same. It should be the same since I duplicated the sequence. Also when I make a compound clip it also adds a gap between clips inside the compound. So even if the two projects had different frame rates what's the point putting gaps in the compound which I make inside the original project?
Fix it in Pre.
Thanos Papadopoulos
on Sep 14, 2017 at 6:18:10 am
Now I see that its putting a gap even when I copy-paste clips even inside the same project. I guess it's some kind of gap.
Fix it in Pre.
Jeremy Garchow
on Sep 14, 2017 at 3:17:10 pm
Instead of duplicating, try making a new Project.
Does the footage not match the frame rate of the Project?
Do you have retiming applied?
I have seen these gaps appear before but it's when the footage and Projectbframe rates don't match, or have been placed in a Project with a different frame rate and pasted in to another frame rate. Especially when the frame rates are close , like 24 vs 23.98, or 23.98 vs 25, etc.
Thanos Papadopoulos
on Sep 23, 2017 at 9:29:36 pm
There is some material with different frame rate. But fcp x supposed to have no problem with mixed frame rate. Also I wanted to simplify my timeline to send it to davinci so I put all my clips to my primary storyline.
I had two ways to do that
A. with the position tool drugging down the clips
B. With the shortcut cmd+ alt+ down arrow.
Bothways there were some clips that there was no way of going straight down. The clips were going a few seconds back or forward like they had anothere place in the primary storyline than the secondary.
Fix it in Pre.
Jeremy Garchow
on Sep 23, 2017 at 10:10:05 pm
[Thanos Papadopoulos] "But fcp x supposed to have no problem with mixed frame rate. "
Sometimes it does.
