Keyboard shortcut for set all 'Transform' keyframes?
Brian Thomas
on Sep 10, 2017 at 4:49:07 pm
I looked in the Help file but couldn't find it.
Many thanks in advance, Brian.
FCPX and PPro 6. iMac 24 + MBP 15". Near Geneva, Switzerland
Robin S. Kurz
Re: Keyboard shortcut for set all 'Transform' keyframes?
on Sep 11, 2017 at 12:13:29 pm
Simply hit ⇧T and the keyframe button at the top left of the viewer?
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Brian Thomas
on Sep 11, 2017 at 12:30:06 pm
Thanks Robin but what I'm trying to avoid is constantly moving the mouse up to a relatively small target being the little keyframe icon between the keyframe navigational buttons.
The thing is, as I edit I usually have transform 'on' as I'm frequently changing 'Position' and 'Scale' - I do a lot of multicam singing and dancing stuff and most of my camcorders are static. It would be great to be able to click on a clip and use a keyboard shortcut to get all Transform keyframes set exactly where I am at that point.
So, any ideas....?
Robin S. Kurz
on Sep 11, 2017 at 12:46:35 pm
The only way you'll be able to do that (that I know of) is have the Videoanimation-Editor (⌃V) open for the clip, select the Transformation bar and hit ⌥K when you need it…
- RK
Brian Thomas
on Sep 11, 2017 at 1:13:55 pm
Again, thanks Robin, certainly an approach but not as easy as I'd hoped. I'll put an enhancement request in but I won't hold my breath in anticipation of it being implemented...
