Understanding Moire in FCPX?
Kasey Gay
on Aug 28, 2017 at 1:48:53 pm
Hey team,
I'll post some video comparisons soon, but I was hoping you guys could help me understand how to get better results from my exports out of FCPX.
(I don't really understand what moire is. What causes it. Or what its identifying characteristics are. Please explain this me?)
But essentially, Ive been shooting real estate videos with a drone and Sony camera. My raw files look great when I view them in quick time. But once I dump them into FCPX, grade, and export, everything has this layer of grime on it.
Is there any essential list you guys can throw me about possible solutions of why this is happening? My exports look like they've lost almost a full generation of quality by the time they come out the other side.
I've double checked that my frame rate matches. Optimized my media. And exported in both h264 and Pro-res 422. I've seen other people suggesting playing with field dominance over ride, and I really don't know what these things are yet.
I'm going to start an upload of my footage off the drone right now. Will post the link.
Thanks guys
Noah Kadner
Re: Understanding Moire in FCPX?
on Aug 28, 2017 at 2:08:22 pm
Which drone?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Kasey Gay
on Aug 28, 2017 at 4:35:28 pm
Drone is a phantom 4 standard.
I also shoot on Sony mirrorless cameras. An a6000 and occasionally an A7S II.
I feel like I'm making mistakes somewhere that's costing me quality. I believe I'm making the "right choices" but still end up with export mush.
I've never tried using Premiere before, but I didn't know if that platform offered more precision in how it exported that might help me along.
Steve Connor
on Aug 28, 2017 at 4:46:59 pm
[Kasey Gay] "I believe I'm making the "right choices" but still end up with export mush.
I think you're probably not as I have zero issues with quality of encoding out of FCPX with footage from those cameras.
[Kasey Gay] "I've never tried using Premiere before, but I didn't know if that platform offered more precision in how it exported that might help me along."
Not really! Give us more details about exactly what you're export settings are and post a link to an example of the problems
Kasey Gay
on Aug 28, 2017 at 5:08:19 pm
Hey Steve, Thanks for the reply.
Here's some recent stuff that's been coming out of the cameras.
I'm trying to get some of the raw originals onto youtube for comparison. I really just need someone with a greater knowledge base to tell me where I'm breaking my footage at.
I JUST re-exported and uploaded this to youtube with these settings.
. (is currently uploading)
I mean, feel free to tell me I'm a monkey who just can't get his exposure right, or is wrecking my footage in the grading process.
Just trying to figure out where my miscarriage is happening so I can start improving.
Thanks team!
Steve Connor
on Aug 28, 2017 at 5:38:25 pm
Do you know what data rate you are using? Youtube compression is very unforgiving!
Kasey Gay
on Aug 28, 2017 at 6:22:38 pm
Is there a selection for data rate in FCPX?
I shoot 4k on the drone, and I was shooting like 60-100mbps in the a7.
Are there other additional setting in FCPX to sniff out?
Steve Connor
on Aug 28, 2017 at 7:04:53 pm
Do you have Compressor installed as well
Kasey Gay
on Aug 28, 2017 at 8:12:40 pm
I have access to it, yes.
Should I be exporting master files/uncompressed and then exporting through compressor?
Steve Connor
on Aug 28, 2017 at 8:23:11 pm
[Kasey Gay] "Should I be exporting master files/uncompressed and then exporting through compressor?
No, you can use add compressor settings to FCPX export
Sam Lee
on Aug 29, 2017 at 12:48:24 am
I have similar problems using consumer level drones with 8-bit, long-gop drone originated footage. The most common is slight dithering and color banding that originated in the highly compressed 60 Mbps MPEG-4. It's not just me. I see numerous of other productions that originated in consumer level drones shot in UHD and downsampled to 1080p. There are simply too much video artifacts. Did you try to shoot in RAW? At this level, any moire pattern and other common artifacts should not exist. But the costs will be quite high.
What helped was shooting in 1080p. But video artifacts are not 100% though due to the moderate amount of video compression already exist before the file is processed in FCP X. You can blame the compression originated in the raw .mp4s for these artifacts.
Unfortunately these artifacts will fail qc if submitted to major OTT platforms (Netflix, Amazon Video) are good examples.
Robert Olding
on Aug 29, 2017 at 5:18:52 pm
The problem isn't moire, it's compression. The cameras you mentioned record video using Sony's AVCHD codec for the a6000 and Sony's XAVC S codec for the A7S II. Both these codecs compress your captured footage to give you the smallest possible file that still looks great during playback. But, once you start to grade the footage, it begins to fall apart and you'll see artifacts such as those in the edited footage you've shown us.
In the example of the output settings you shown us, you've chosen the H.264 codec. The H.264 codec compresses the footage even more. What you have are original highly compressed XAVC S files being compressed even further during output. This combination will make the final edited movie look terrible.
Converting the original captured footage from either of these cameras to ProRes or some other codec before editing won't solve the issue. Check to make sure you're using the latest version of Final Cut Pro X and see this Apple Support document about importing files encoded with Sony codecs into Final Cut Pro X.
I would recommend not converting the footage to ProRes before you edit. I would also recommend that you edit in the original resolution. If the footage was shot in 4K, edit in 4K. The idea is to keep as much as of the original data as possible before you output. Once your ready to output, I would recommend that you output a master file at the original resolution and select the ProRes 422 HQ codec.
Run that master file through Apple's Compressor to knock it down to the size you'd like to actually deliver to your client but leave the codec at ProRes 422 HQ. If you want to show the movie on YouTube, use the "Publish to YouTube" preset that is available in Apple's Compressor.
To alleviate the issues associated with highly compressed capture files, it would be best to capture your footage in a codec that is more forgiving. Atomos and other companies make external recorders that you can attach to the A7S II via the HDMI output on the camera. This will allow you to capture the footage in various ProRes or Avid DNxHD codecs allowing for a much higher quality of captured footage that will hold up during editing and grading.
Just an FYI on moire ... the quality of the processing that happens in camera during capture has gotten so good that moire isn't seen that often anymore. Once in awhile, I'll see it on clothing that has a printed pattern of vertical or horizontal stripes on it such as this example.
Robert Olding
http://www.8streetstudio.com
Minneapolis, MN
Loren Risker
on Aug 29, 2017 at 10:23:41 pm
2 questions:
Does your project have the same framerate and resolution as your source footage?
Are you viewing your footage with a viewer size of 100%, both when you see your good looking raw and your export? Scaling will add moire and other artifacts during playback only.
OutOfFocus.TV - Music Videos 24/7
Kasey Gay
on Aug 30, 2017 at 1:30:50 am
Hey guys,
Thanks so much for the in-depth feedback and responses. I feel like you guys stand to save me months of trial and error.
Robert, not to steal anymore of your time, but I just want to make sure I’m understanding everything.
1. My knowledge up until this point said that transcoding to Pro-res was actually BETTER for color grading. I take it the people giving me this advice weren’t accounting for the fact I was shooting on Sony.
2. If buying an external recorder isn’t in my price range yet, would I possibly be getting better results by avoiding shooting SLOG and flat profile, and instead sticking with the *in camera* colors.
3A. Loren both you and Robert have encouraged me to make sure I’m editing in the same resolution and frame rate as I shot in.
The Sony a6000 only shoots 1080, but the Phantom shoots 4k, and Im’ using them both. Is there a best practice to follow in this situation? When using a slider, I like to shoot 60fps on the Sony, but I can’t get that out of the drone. Is there any way to reconcile the two, or am I asking for trouble if I don’t get both cameras running identical settings?
3B. When we say “edit in the same frame rate/resolution. We mean only the time line, right? Example, if I shot in 60 FPS with intention to slow down playback, I’ve operated under the impression that I could have my time line be 24 FPS, and then drop that 60fps clip in and have it slowed down. (Not arguing. Begging to be corrected)
Thanks so much for your time guys. Your advice is invaluable.
-Kasey
Loren Risker
on Aug 30, 2017 at 6:04:14 am
Its not a hard rule to match the resolution and the frame rate.
But here are a couple things to look out for.
Scaling can add artifacts such as moire and softening.
Say you have some 4k footage, and the rest of your footage is 1080p. If you put it in a 1080 project, the 4k will need to be cropped, or scaled down. If you have a 4k project, all of the 1080 footage will need to be scaled up.
As for frame rate, you can make it anything you want and mix framerates. However, it you play the frames in such a way that the computer has to create or drop frames, it will add some visual artifacting.
For instance if you have a 30fps project and you had a 60fps clip, if you play the 60 frames at your project rate you'll get slow motion (50% speed). If you chose something slower, like 15% speed, the computer would have to make up frames or repeat frames, and you'll see a strong drop in quality.
If you put it
Robert Olding
on Aug 30, 2017 at 3:33:17 pm
[Kasey Gay] "1. My knowledge up until this point said that transcoding to Pro-res was actually BETTER for color grading. I take it the people giving me this advice weren’t accounting for the fact I was shooting on Sony."
Hi Kasey ... ProRes IS better for EDITING in Final Cut Pro X. The size of video files are typically very large and the ProRes codec was designed to work exceptionally well in Final Cut Pro X and other NLE's such as DaVinci Resolve and Adobe Premier. When editing, you're not changing the quality of the footage in any meaningful manner, you're just arranging the footage to tell a story.
When you color grade, you are actually changing the footage from one thing into another. This is a destructive process. It may appear that you're adding data (a constructive process) but in reality, you taking data away. Since your original footage is already compromised by high compression you're actually making it worse by modifying the color. The higher the quality of the original footage, (meaning the less compressed it is), the better it will hold up while you actually destroy it.
The high compression that exists in your original footage won't be made better by converting it to a higher quality codec such as ProRes 422. It will just be easier to edit. Any footage you convert will include the limitations of the original and possibly introduce new artifacts because the software has to interpolate the original into something new.
Robert Olding
Minneapolis, MN
Robert Olding
on Aug 30, 2017 at 3:49:24 pm
[Kasey Gay] "2. If buying an external recorder isn’t in my price range yet, would I possibly be getting better results by avoiding shooting SLOG and flat profile, and instead sticking with the *in camera* colors."
Yes you would. The only reason you'd want to shoot with any of the "flat" profiles is if the scene has too much contrast that you can't control by any other means.
Once your able to capture footage with a higher quality codec, color grading in post will be more forgiving. This will allow you to use a "flat" profile in scenes that may not require it.
Robert Olding
Minneapolis, MN
Robert Olding
on Aug 30, 2017 at 4:26:37 pm
[Kasey Gay] "3A. Loren both you and Robert have encouraged me to make sure I’m editing in the same resolution and frame rate as I shot in.
The Sony a6000 only shoots 1080, but the Phantom shoots 4k, and Im’ using them both. Is there a best practice to follow in this situation? When using a slider, I like to shoot 60fps on the Sony, but I can’t get that out of the drone. Is there any way to reconcile the two, or am I asking for trouble if I don’t get both cameras running identical settings?"
As Loren stated, you're either going to have to scale the 1080 footage up to 4K or scale the 4K footage down to 1080. As a rule of thumb footage that has been scaled down will look better than footage that has been scaled up.
The FPS is much less likely to matter much if at all. If your project timeline is at 24 FPS and you add footage to the timeline that was shot at 24 FPS it will appear to play at normal speed. Any footage that was shot at a FPS higher than 24 will appear to play in slow-motion. Any footage that was shot at a FPS less than 24 will appear to play in fast-motion.
Footage will be interpolated by the NLE when you ask the NLE to slow the footage from what it was shot at. So, if your project timeline is at 24 FPS and you add footage to the timeline that was shot at 24 FPS then ask the NLE to slow the motion, the NLE will have to interpolate the original footage and will add frames that didn't exist before . This could introduce artifacts.
The reverse is the opposite. If your project timeline is at 24 FPS and you add footage to the timeline that was shot at 24 FPS then ask the NLE to speed the motion, the NLE will delete frames from original footage. This will NOT introduce artifacts since this is actually removing frames and nothing new is being created.
Robert Olding
Minneapolis, MN
Robert Olding
on Aug 31, 2017 at 8:00:41 pm
Kasey ... I forgot to mention that you can transcode your footage into a ProRes proxy file. Edit and grade using the proxies. Then conform your original footage to the final proxy cut. This will make it easier to edit and grade than using the original Sony files. It may or may not help with the artifacts that are introduced once you output.
Robert Olding
Minneapolis, MN
Robert Olding
on Aug 30, 2017 at 4:34:18 pm
Kasey ... consider purchasing Neat Video. It's a miracle worker on footage that doesn't look so great either from capture or from the destruction caused in post.
Robert Olding
Minneapolis, MN
Michael Sanders
on Aug 31, 2017 at 9:27:01 pm
Moire is a result from when the when high frequency detail is close to the resolution of the camera or display. And as others have pointed out compression can also cause problems as well.
There is a scene in an episode of The Crown (one with fine tweed) which exhibited Moire when I watch via an Apple TV. I checked with a friend who worked on it and he said it was clear on his monitor during post - but then he was watching on a top end Sony 4K monitor from the RAW files ☺
http://www.xdcam-user.com/tech-notes/aliasing-and-moire-what-is-it-and-what...
Michael Sanders
London Based DP/Editor
Kasey Gay
on Sep 2, 2017 at 1:59:03 am
Thanks for all the help guys.
I think I'm getting a better sense of it all. It's particularly useful to know what moire means, and that I've got compression issues rather than moire. One less thing to wrestle with anyway.
I appreciate the generosity with your time.
I also took you guys up on the advice to look into neat video. It's been useful to me so far, but I'm struggling with it a bit.
Particularly, I thought I'd been told to 'Denoise' video before grading. But it would seem that applying neat video makes color grading nearly impossible (system lag) on a clip that has neat video running....
Yikes. :/ Thanks for the time gentlemen.
