Sony SSTP files
Michael Sanders
Sony SSTP files
on Aug 26, 2017 at 10:34:44 pm
Hi All.
I'm trying to edit some SSTP RGB files from the F55. I'm 99% sure this has worked before.
I run them through SR viewer to turn them into Quicktime .MOVs and then import to FCP X. I have the SR codec installed.
I can see the files in the browser complete with thumbnails but when I try to play or skim the file goes black.
Any ideas? Could it be conflicts with various codecs and plugins?
Thanks.
Michael
Michael Sanders
London Based DP/Editor
Jeremy Garchow
Re: Sony SSTP files
on Aug 26, 2017 at 11:44:24 pm
Why not use the SSTP MXF files in FCPX directly?
Michael Sanders
Re: Sony SSTP files
on Aug 27, 2017 at 7:38:43 am
Hey Jeremy,
I have tried that but it doesn't seem to want to know - hence the question could there be an issue with my system, possibly various older codecs?
I have installed the Sony SR codec and removed the Sony MXF import plugin which has made no difference.
As I said I can see the files in the FCP X browser but can only see thumbnails.
Any ideas?
Michael
Michael Sanders
Jeremy Garchow
Re: Sony SSTP files
on Aug 27, 2017 at 2:13:30 pm
You've tried the usual restart and trash prefs?
I've noticed that in 10.3.4, FCPX seems to take a really long time to build a cache and I've seen the black screen on ProRes movies too. If you can see thumbnails, that's a decent sign that the codec is working.
I'd try deleting the .mov versions out of there, drag and drop MXF files. I'd also trash your cache.
Michael Sanders
Re: Sony SSTP files
on Aug 27, 2017 at 7:13:40 pm
So the plot thickens..
I trashed the prefs and created a new Library, importing the files directly into it.
Now when I press play I see the image but if I pause it, or add an effect it goes black.
The really bizarre think is that if I create optimised media I just get a green screen.
Will have to send a bug report to Apple I think..
Michael Sanders
