copy and paste time code for transcripts
Roger Sherman
on Aug 2, 2017 at 9:55:47 pm
Is there a way to copy time code and paste into a google document?
Mark Smith
Re: copy and paste time code for transcripts
on Aug 3, 2017 at 12:25:10 pm
I'll take a stab at this :
In the browser, list view, copy time code, start/end from the fields in the browser and paste into google doc?
If you have keywords or favorites applied to clips, timecode copied from the browser would reflect those ranges...
also If you have Producer's Best Friend app, you can export lists clips used in a sequence or browser to an excel spreadsheet and can select what info you want exported. This might be your magic bullet which would take advantage of the logging, tagging, keywording work done organizing a library and then pushing it out in an organized way to a format you could then filter/import into a google doc.
Andreas Kiel
on Aug 3, 2017 at 2:58:50 pm
Create a shortcut for the "Edit -> Copy Timecode" menu.
Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Jeremy Garchow
on Aug 3, 2017 at 5:33:39 pm
[Andreas Kiel] "Create a shortcut for the "Edit -> Copy Timecode" menu."
This is the way to go. I have mapped this to control-option-command-c.
And paste timecode to contol-option-command-v:
