Importing media question
Don Scioli
on Jul 27, 2017 at 10:18:39 pm
Hi, with the 10.3 upgrade, I noticed that when importing footage from my Canon XF300, say a clip is labeled AA4820,
there will be an identical clip labeled AA48201, basically adding a copy of the same clip with an extra numerical.
I've just been deleting them , but can someone explain what is happening.
thanks in advance.
Noah Kadner
Re: Importing media question
on Jul 27, 2017 at 10:41:27 pm
Are you sure it's not part 2 of a long clip?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Don Scioli
on Jul 27, 2017 at 10:56:56 pm
No, it's an exact dupe, yet sometimes it's broken up into smaller clips with ascending numbers on each one. The "good" clips do not have the extra end number.
Noah Kadner
on Jul 28, 2017 at 12:03:59 am
Are are your drives HFS+?
Noah
Don Scioli
on Jul 28, 2017 at 12:10:36 am
I'm using a Raid drive. 2 drives in there, Mac OS Extended (Journaled). Never had this problem until 10.3 the previous versions of FCPX were fine with this drive
Noah Kadner
on Jul 28, 2017 at 12:15:58 am
I'd suggest reinstalling the latest plugins for your camera.
Noah
Don Scioli
on Jul 28, 2017 at 12:33:48 am
Many thanks, I probably had an older version. Will try tomorrow.
Don
Brett Sherman
on Jul 31, 2017 at 1:44:30 am
This is how Canon XF names it's files on the card when it records. It sticks a 1 on the end for the first clip, if it's a long clip, then it splits it into multiple files 2, 3 and so on. When you use the Canon XF FCP X plug-in it eliminates that last number and combines all clips together into a single .mov. If you import the .mxf files without rewrapping that's exactly how it will come in.
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
