Decoding XML Import Warnings
Ellen Bittner
on Jul 11, 2017 at 7:19:20 pm
Hi Guys,
I got the following warning when importing an XML. Everything appears fine in the project, but I'm worried there's something I didn't get that I don't know about. This is the warning:
Your XML was imported with the following warnings:
The effect ID is invalid. (ref="r10": /fcpxml[1]/library[1]/ event[1 ]/project[1 ]/sequ ence[1 ]/spine[1 ]/asset-cli p[1 ]/filterĀ­video [1 ]/@ref)
Anyone know what this XML import warning might be related to or how to read this warning in general so that I can find the culprit? Thanks!
- Ellen
Jeff Kirkland
Re: Decoding XML Import Warnings
on Jul 11, 2017 at 9:11:33 pm
What was the XML created in? I'd guess you're missing an effect but these messages are so cryptic it can't be more than a guess.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Ellen Bittner
on Jul 11, 2017 at 9:21:25 pm
Thanks, Jeff.
The XML was created in FCPX, with Metadata View set to "General" and XML Version set to "Current Version (1.6)"
I didn't bring the XML through any other software, just straight from one apple computer to the other, both with the same version of FCPX running. I appreciate your guess at what's going on here!
- Ellen
Thank you,
Ellen
Jeff Kirkland
on Jul 11, 2017 at 9:54:04 pm
You might try running the XML through X-FX Handler. It can show you any effects, title or generators that are in the XML but unavailable on your computer.
http://www.spherico.com/filmtools/X-Files/X-FXHandler/
Ellen Bittner
on Jul 11, 2017 at 10:16:01 pm
Thanks, Jeff! That was just what I needed to de-code my FCPXML. I love this community!
Thank you,
Ellen
