Which FCPX Audio plugs will improve off-mic recording?
Mark Suszko
on Jun 15, 2017 at 9:23:51 pm
Client handed me footage shot (vertical, of course) with an iPhone. I'm dealing with audio that's not unusable, but it does sound "off mic" and a bit hollow. Entertaining suggestions of which of the existing plugs in FCPX will fatten up that sound, reduce the hollowness, make it sound more as it should.
Noah Kadner
Re: Which FCPX Audio plugs will improve off-mic recording?
on Jun 15, 2017 at 9:46:30 pm
The freebies will take it to a certain level- noise reduction/normalization. But to really fix bad sound you need:
http://www.crumplepop.com/fcpx-premiere-audio-plugin-echoremover/
Convince the client that $99 to buy you the plugin is a lot cheaper than the reshoot they deserve.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Mark Suszko
on Jun 15, 2017 at 9:52:14 pm
Thanks, Noah, which "freebies" in particular?
If I had money I'd buy Izotope.
I don't have that kind of money right now, nor do my clients.
So the freebies will have to do for now.
Noah Kadner
on Jun 15, 2017 at 10:42:01 pm
No freebies beyond the built in enhancement tools in X- and some creative EQ/Compression. Garbage in garbage out as they say.
Noah
Jeff Kirkland
on Jun 15, 2017 at 11:29:57 pm
For $129 izotope RX elements probably has all the tools most editors would need to fix the audio issues they encounter day to day and way better than anything built into FCPX.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Gregor Queck
on Jun 16, 2017 at 8:51:17 am
It depends on the material, every recording needs a different treatment.
Can you send me a short clip, I will try what I can do.
Cheers, Greg
