Editable text
Al Flores
Editable text
on Jun 13, 2017 at 3:59:42 pm
Hi guys! I'm having such a hard time with this, once you have your layers in PSD, once you're in FCP... Can you edit the text in FCP or you need to go back to PSD and edit the text? Can't you do it directly in FCP? Thanks by advance!
Shane Ross
Re: Editable text
on Jun 13, 2017 at 7:11:45 pm
No...the text is part of the PSD file. If done in PSD, it needs to be changed in PSD. Even FCX can't dig into a PSD file and change the text.
Sorry
Shane
Little Frog Post
Al Flores
Re: Editable text
on Jun 13, 2017 at 8:44:23 pm
That's very sad news Shane! I need to change hundreds of pieces and i wanted to build a master piece and changed it directly. Wow... Thank you!
Dave Jenkins
Re: Editable text
on Jun 14, 2017 at 5:03:15 am
You should add your PSD to a Motion file without the text and use a Motion Title published to FCPx and the text can be changed in FCPx
Dajen Productions, Santa Barbara, CA
Mac Pro 3.5MHz 6-Core Late 2013
FCP X
