External Playback monitor while keeping both viewers on main monitor
Steve Horswill-Johnston
on Jun 11, 2017 at 9:47:46 pm
Hello all,
I'd like to have an external playback monitor but keep both viewers on my main monitor. Possible? If it requires a Matrox box (or similar) what is the hardware I need? I know I can place viewers on the external monitor, but it removes it from the main monitor. I want to keep them in both locations.
Thanks in advance!
Steve
Final Cut 10.3.4
iMac (Late 2013, latest OS)
Jeff Kirkland
Re: External Playback monitor while keeping both viewers on main monitor
on Jun 11, 2017 at 11:53:57 pm
setting AV Out to on in the menu should tell FCPX to use your external monitor as a broadcast display.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
on Jun 11, 2017 at 11:59:23 pm
Thanks. For some reason, I'm not able to make any change to that setting. You're talking about in preferences/playback, correct?
Jeff Kirkland
on Jun 12, 2017 at 6:48:18 am
You're in the right spot. How is your monitor connected to the Mac? From memory it has to be connected via HDMI to show up.
