Fast motion vs slow motion
Joe Lukus
on Jun 10, 2017 at 6:55:59 pm
Ok so when you slow down a movie I know shooting at a higher frame rate will give for a smoother slow-mo when slowed down...
Now is it better to shoot at higher frame rates as well when speeding up? Better to have more frames to drop out? Or will the desireded 24 fps look or is the best to shoot at when speeding up a video? Could not find really any good information out there for speeding up video.... find good info for slow mo, but fast-mo; so does it just doesn't matter what you shoot at for speeding up video??? Speeding up videos just drops frames and plays them faster right?
Just trying to understand what's the best way to go about speeding up a video and if I need to be conscious of what I shoot at before hand if I want to speed up?
Noah Kadner
Re: Fast motion vs slow motion
on Jun 11, 2017 at 6:08:38 am
Depends what exactly you're trying to achieve- comical effect or special effect etc. Shutter speed can also make a huge impact on top of frame rate when altered in post.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Joe Lukus
on Jun 11, 2017 at 1:34:49 pm
Could you happen to tell me what settings I would want to aim for, for just a nice smooth fast motion as to basically just speed up the video to preserve the video quality, not wanting to go for any special effect or anything... just want to speed up the video...
If there is any good info or videos out there that you could point me too around this subject that would also be great!
Jeremy Garchow
on Jun 11, 2017 at 2:06:04 pm
What camera are you using? Does it have low frame rate shooting, like 4fps?
This allows you to control motion blur, saves a ton of card space, and can be further sped up if needed.
Otherwise you may need to add motion blur in post to get rid of some of the sharp/strobing feel.
Joe Lukus
on Jun 11, 2017 at 7:44:23 pm
That what I was thinking lower frame rates can give better/smoother fast motion (speed up)
so just the opposite of slow-mo with higher frame rates....
I am currently just working with aerial footage along with some GoPro footage.... I'm going to check to see how low the drone will go on frame rates.
Also was thinking about timeline FPS and how this all fits in with "over ranking" and "undercracking"... now would you really ever want to pick anything other than 24fps/23.976 etc...? If you are wanting to stick with that "relastic" film/cenimatic look?
Basically anytime you are wanting to speed up or slow down a part, you either shoot higher or lower frame rates from you desireded timeline fps or output frame rate, right?
Which I was thinking is pretty much always going to be 24/23.976?
Just trying to get the proper workflow to achieve smooth speed ups or slow downs!
Thanks again for everyone helps so far....
Jeremy Garchow
on Jun 12, 2017 at 12:06:59 am
[Joe Lukus] "That what I was thinking lower frame rates can give better/smoother fast motion (speed up) "
It's also about exposure per frame that will give you more or less motion blur, not just frame rate, although they are intertwined.
I don't believe DJI or GoPro products go below standard frame rates on video. GOPro has more options on the still side.
I'd download the demo for RevisionFX Reel smart Morion Blur plugin which can help smooth out the shots by adding more motion blur if you don't get enough in camera.
http://revisionfx.com/products/rsmb/
Joe Lukus
on Jun 13, 2017 at 1:06:23 am
Thanks will have to check that out!
But again I'm I correct that if you are going for the film/natural motion look then 24/23.9 is what you should always be shooting for? As the desired output frame rate?
Jeremy Garchow
on Jun 13, 2017 at 1:28:39 am
We sometimes shoot 29.97 with drone footage (especially if they are big wide vistas) and slow down to 23.98 to smooth it out.
Sometimes we shoot at 23.98 if there's a lot of people in the shot.
Joe Lukus
on Jun 13, 2017 at 3:37:14 am
Hmm never thought about doing that to slow it down, to give it a nice smoother slower feel!
Thanks again for all your help!
Joe Lukus
on Jun 13, 2017 at 10:31:24 pm
I was going to make another thread but hopefully someone will see this... still on the topic of speeding up/down video...
So I was reading somewhere were they were talking about matching frame rates so that when you are over cranking or undercracking, you want to pick rates that evenly go into each other or divisible? I think it was saying... wish I could find the page!
Because with frame rates of 23.976... but I I can see with 30 frame and 60 etc...
Can anyone elaborate?
Does this have any impact on choosing a frame to shoot at when match your timeline fps?
Jeremy Garchow
on Jun 13, 2017 at 10:52:36 pm
All of this is wholly dependent on what you want your footage to look like in the end.
FCPX, in my opinion, does a remarkable job off speed. It has a function, no matter what frame rate you shoot, you select the clip and choose "automatic speed" it will play back the frames 1:1 according to your timeline with no interpolation. So if your shoot 60fps, have a 30fps timeline, fcpx will slow the footage down by 50%. If your shoot 60 and have a 24fps timeline and chose automatic speed, FCPX will slow the shot down by 40% and play the 60fps back at 24 and give you a 40% reduction in speed. If you need to go further, you can turn on Optical Flow and FCPX will interpolate the frames in between. The quality of this is dependent on the footage. Generally it does a great job. Typically with slow motion, you want to shoot at the highest frame rate possible with your given camera. We shoot a lot at 240fps from our f55 and speed up the slow motion if necessary if 240 comes out too slow. And if we need 4K footage, we can only go to 120fps with our setup. I believe GoPro and DJI only goes to 30fps in 4K.
It really does depend on your subject, camera, and desired outcome. Consult the internet about FCPX optical flow to see possibilities. Older tutorials will have the controls in a different place, but the same controls are available in the latest version of FCPX.
Joe Lukus
on Jun 14, 2017 at 10:40:26 pm
I guess it would be simplest to put it this way...
When not using automatic speed in FCPX which keeps all the frames and just slows or speeds them up depending on timeline FPS...
If I were not to use automatic speed and just let FCPX match the timline FPS by rate conform (floor, blend, optical flow...) as it ether starts to drop frames or make up frames....
And say I shoot in 60fps would placing that in a 30fps be better, look better since it will just drop every other frame, than if I placed it in a true 24FPS or even worse 23.987... as it is now not a nice 1 frame drop?
Larry talks about this a bit in one of his articles and show how conforming 60fps to a 24fps can make for not the best convertion as it drops 1 frame then 3 frames etc...: https://larryjordan.com/articles/frame-rates-are-tricky-beasts/
So again was wondering if maybe keeping just even number frame rates are the best when having to mix different frame rates at times? Or will the notice not be that big of a difference and I just need to stop worrying about this lol?
Thanks again for your help!!! I really do appreciate it!!! Enjoy learning this art, but there is a lot to it!!! Lol
Jeremy Garchow
on Jun 14, 2017 at 11:10:42 pm
[Joe Lukus] "And say I shoot in 60fps would placing that in a 30fps be better, look better since it will just drop every other frame, than if I placed it in a true 24FPS or even worse 23.987... as it is now not a nice 1 frame drop?
If you need 30fps, shoot 30fps. if you need 24fps, shoot 24fps. If you need slow motion, shoot a higher frame rate and conform to the timeline fps.
[Joe Lukus] "Larry talks about this a bit in one of his articles and show how conforming 60fps to a 24fps can make for not the best convertion as it drops 1 frame then 3 frames etc."
This is if you shoot 60, and then need regular motion from the 60fps in a 24fps timeline, yes, FCPX will drop frames. But FCPX does a really really good job on frame rate conversions when going from 60 to 24.
But if you don't need slow motion, just shoot at your timeline frame rate.
Joe Lukus
on Oct 8, 2017 at 5:58:20 am
Ok guys I have been wondering this lately, still related to this topic.
In simple terms what FPS/camera settings do they film at to capture fast motion like a car going fast with fast pans etc or "in the car view" of it racing down the road with the landscape flying by (think of drone flying through the air fast). Just "fast motion"/speeding up in general.
Because they output at 24fps, so how are they filming fast motion/creating fast motion to get a nice and smooth "fast motion"?
Because if you speed up 24fps in post it can make for stuttering etc... (taking out frames) and if you physically move the camera fast as in panning fast etc.. at 24fps it leads to choppiness, so again how can they record fast motion or speed up the video without jitteriness...
Do they film at like 8FPS and dump in 24FPS which would speed up, but then again you are not capturing all the motion that goes by, again leading to choppiness? or do they film with high frame rates to capture all the motion, but then when they drop it into a 24fps timeline it would be slowed down defeating the purpose! and if they conform and speed it up they are just again tossing away frames to again create a choppy fast motion?
Put another way, how do they simulate "fast motion" on the big screen, scenes that go by quickly (another example, like a video that pans/circles around a building at "normal speed", but then speeds up as it goes around the building) without making the scene choppy? (One or my reasons for asking the question)
Easy to get smooth slow-mo, just shoot high FPS and then dump into 24FPS timeline, but NO ONE talks about what you do for FAST MOTION?!, and again thats what I want to know!
Hope this all makes sense and you can see were I am coming from?
Thanks!!!
brecht dhuyvetters
on Aug 24, 2018 at 3:01:40 pm
I actually have the exact same question! I still haven't found a good answer to this after searching for quite a while on the web. This
illustrates it well at 1:18.
