Can i save animated 4 x solid/text layers into single effects preset?
Luke Watson
on Jun 6, 2017 at 3:36:05 pm
I have a lower third consisting of 2 x custom color blocks (cropped) and 2 x text layers,
all animated using slide transitions to slide onto screen, and fade out transitions at the end,
is it possible to save this whole set as a single pre-set effect?
Or do i have to rebuild in Motion and save into FCPX that way?
Luke
Andy Neil
Re: Can i save animated 4 x solid/text layers into single effects preset?
on Jun 6, 2017 at 5:13:28 pm
You need Motion to build this effect and save it as a lower third title in your title browser. It's worth having Motion if you like to make custom gfx like this for your projects.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Luke Watson
on Jun 6, 2017 at 6:39:18 pm
Thanks -was hoping I could do this within FCPX but no worries, I'll build and export from Motion
