No playback on two audio channels imported as 'four mono'
Jesse Freeston
on Jun 5, 2017 at 10:09:24 pm
FCPX imports audio as 'Four Mono' with audio from the lapel and boom mics on channels 1 and 2 respectively. Channels 3 and 4 are empty. The waveforms show and the meters go up and down, but there is no playback. (see screengrab)
If I switch to 'Two Stereo' in the Inspector I can hear the playback, but I lose the ability to adjust the levels of the two mics individually.
Any ideas?
I am editing on OS X Sierra and FCPX 10.3.1.
Shot with Sony PXW-X70.
Jesse Freeston
Documentary Filmmaker/Editor/Shooter
Duncan Craig
Re: No playback on two audio channels imported as 'four mono'
on Jun 6, 2017 at 9:08:26 am
Edit the multicam clip into a timeline and it will playback the audio.
I'm having the same problem here.
It's happening since I update to the recent version, I expect it's a 'feature' of the new Roles related stuff, but it's a real PITA.
FS100, EX1, GoPro, 2x Hacks, FCPX etc
Jesse Freeston
on Jun 20, 2017 at 9:01:25 pm
Hey Duncan!
That's what I've been doing too, a bit of a PITA as you say. Have you found a solution in the last couple weeks?
Jesse Freeston
Jeff Markgraf
on Jun 21, 2017 at 12:06:04 am
Duncan & Jesse -
See the reply to Ben above (or below) this thread and try the MIDI configuration fix. Hope it helps.
