Multi-Cam Shoot- Drop Frames in Playback
Rachel Bradshaw
on Jun 4, 2017 at 8:24:35 pm
Hello,
I recently shot a short film using two digital cameras. For some reason the playback of clips from one of the cameras is dropping frames when played on the timeline. I reduced the playback resolution to 23%. I even went as low as 12.5%.
Possible solutions?
Thank you,
Rachel
Jeff Kirkland
Re: Multi-Cam Shoot- Drop Frames in Playback
on Jun 4, 2017 at 8:56:49 pm
If by playback resolution you mean you reduced the size of the timeline viewer then as far as I know that makes no difference to FCPX. Your only two options under the quality menu are "better performance" or "better quality".
As far as the multicam goes have you let FCPX optimise the media?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Rachel Bradshaw
on Jun 4, 2017 at 10:32:59 pm
I have not optimised the media.
How should I do that?
Scott Witthaus
on Jun 5, 2017 at 1:16:26 am
I just finished a couple 1 hour, 3 camera multi-cam edits on an older MBP. I went ahead and made proxy media for the edit and just switched back to original for the output. Much better performance.
Scott Witthaus
Owner, 1708 Inc./Editorial
Managing Partner, Low Country Creative LLC
Professor, VCU Brandcenter
Scott Witthaus
on Jun 5, 2017 at 2:59:16 pm
OK, so I was able to find a machine with 10.2.3 and the Library opened fine and I got job done. I did export an XML and imported that into a new Library in 10.3.x and that fixed the issue. However, when I get back to my home studio, I will try your other ideas. Thanks Jeremy.
Scott Witthaus
Scott Witthaus
on Jun 5, 2017 at 3:47:40 pm
Woops, wrong thread. Sorry.
sw
Scott Witthaus
