Exporting AAF to ProTools with X2Pro - subframe synch issues
sam friedlander
on Jun 3, 2017 at 6:06:37 pm
I edited a project in FCPX, exported an XML, and then used X2Pro to create an AAF.
Sent that to my sound/mix facility, and got this message back:
The AAF looks good for the most part, but for some reason everything was a frame early. I pushed it back and noticed that clips are all off by 1-4 sub frames from the guides, and the clip boundaries are off from the frame edges. I'm not quite sure how that happened. Could you please look into that?
Anyone else had issues with things being off by subframes on export??
Any possible solutions?
