FCPX export options stay grayed-out; can't share to file.
Mark Suszko
on Jun 2, 2017 at 4:22:39 am
Slightly older version of FCPX, I have a bit over 6 hours of HD footage painstakingly assembled into a 2-hour rough cut that I wish to export as H.264 or Prores 422, but all the options to export or share remain grayed-out.
I selected everything on the timeline, Hit "render all": this has sometimes fixed the problem in the past. I have done this twice now for the current program without success; the render happens, according to the progress bars, but export/share options still grayed out, no explanations given.
I'm going to try playing the timeline out live, thru my IO system or via Thunderbolt into a KiPro recorder, next, but would appreciate opinions, conjecture, and even helpful advice on the specific problem.
Noah Kadner
Re: FCPX export options stay grayed-out; can't share to file.
on Jun 2, 2017 at 5:36:37 am
Try copy pasting all into a new project timeline.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Mark Suszko
on Jun 2, 2017 at 11:45:11 am
Did that; no difference.
Jeremy Garchow
on Jun 2, 2017 at 12:34:04 pm
Trash your preferences.
Mark Suszko
on Jun 2, 2017 at 3:49:03 pm
Trashed prefs as suggested.... and now the last third of the timeline is a red mess of "missing camera" picons. No biggie, just a day and a half's worth of work went "poof" just now. Panicking? Who's panicking? I got til lunch time to fix this. THEN I'll be panicking.
Jeremy Garchow
on Jun 2, 2017 at 4:48:32 pm
That does seem to point to a much bigger issue, and no wonder things weren't working correctly.
If you match frame the footage, where does it lead?
Mark Suszko
on Jun 2, 2017 at 6:36:31 pm
I re-imported source footage into the fresh library and project file, and told it to render, went to lunch, came back, the bleeding was gone and the timeline restored. Better yet, the export options are back in black, baby! So I'm trying a test export right now. Will take a while, but looks promising for now.
Noah Kadner
on Jun 2, 2017 at 5:31:07 pm
That sounds more like missng media than a bug. Assuming you have the original camera carda you need to reimport the clips that are missing.
Noah
Mark Suszko
on Jun 2, 2017 at 6:40:24 pm
I never have a problem like this if I follow Shane's Law and copy the P2 cards off to folders in my AV drive before importing them. Only when I work with footage where it's not being copied over on import, do I get into these tangles, even though I never removed the P2 from the reader. It's like random "forgetfulness" hits the thing every once in a while - always when you're on a deadline, too.
Maybe that's fixed in the latest build, and if I ever get out from under my current project backlog and clear off ALL the drives, we'll upgrade and see.
Jeremy Garchow
on Jun 2, 2017 at 8:07:21 pm
[Mark Suszko] "I never have a problem like this if I follow Shane's Law and copy the P2 cards off to folders in my AV drive before importing them"
I think this happens when you quit FCPX before it's done rewrapping, regardless of where the media is. The way FCPX works is that you can see and use the media before it's done rewrapping, so if you quit before it's done rewrapping, FCPX leaves you linked to the original media in some sort of "not quite online" state. This seems like it could be programed a bit better to be able to get out of this jam.
This problem pops up from time to time on these forums.
Mark Smith
on Jun 3, 2017 at 1:02:08 am
I've seen this same issue. My wife edits and she is frequently under time pressure and there have been instances where clips were "imported" but not all the behind the scenes business is finished and she closes the project/library/FCPX and then the next time the project is opened there are some clips that are "not quite there", which of course fouls any attempted exports.
Jeremy Garchow
on Jun 3, 2017 at 1:15:42 am
[Mark Smith] "and then the next time the project is opened there are some clips that are "not quite there", which of course fouls any attempted exports."
Sometimes, you can dig in to the library file and delete the alias. This will knock the file completely offline and allow you to reimport with the File > Reimport menu.
Depending on your footage, the alias is sometimes hard to find.
Chris Curtis
on May 15, 2018 at 7:16:52 pm
Share options are greyed out if any of the clips are "camera clips", ie located on a camera or Data card. They will have a camera icon in the bottom left corner of the clip in the browser. To rectify this, select the clip(s) and then go to File > Import > Reimport from camera/archive. Once that's completed, the project should export!
Mark Suszko
on May 20, 2018 at 3:29:01 am
Hey Chris, I've been too busy to respond until just now, but I wanted to say it was providential that you posted your response when you did. The moment it went up, I was in exactly the situation you described, stuck and not sure what was causing it. Your post literally popped into my email in-box as I was getting ready to call for more help and it made me look in the right place to solve the problem. Your timing could not have been better unless controlled by a divine hand. Just wanted to give a belated thanks to you and the others in this thread for the help.
Annnnd...... it's happening again..... but on another project, and this is one where the original footage was first offloaded to a folder in the RAID, and the P2 card ejected, before we even created the project/library/events.
I imported into FCPX from the folder on the RAID, did a swell edit, and now again I can't export it. I'm not at the office to double-check if the camera clip icons Chris mentioned are present, but let's assume they are not, because I've re-imported the raw media twice, and "reconnect media" is not an available option. Everything is there in the timeline, and it will play fine, but no dice when I hit the "render all" or the "Share" commands. Soon as this project is done, I'm going to upgrade the FCPX to the latest build and see if things get more reliable. In the meantime, any other things I might try, to get the pickles out of the jar?
