When FCPX Render Fails
Ken Bennett
on May 31, 2017 at 10:38:14 pm
What are my options to get a Project rendered out to an MP4 when I get this error message:
The share operation "Master File" has failed.
Video rendering error: -50 (Final Cut Pro error -50: renderVideoFrame failed)
Advice??????????
I also get the the following message when I start the Share to MP4, and nothing is showing in the Background Tasks window.
"" has background tasks that are not yet complete.
If you continue, these effects may be missing or have reduced quality: Stabilization
Advice ????
Help!!
THX
Ken Bennett
Video Adventures
Capturing Your Life's Adventures!
Jeff Kirkland
Re: When FCPX Render Fails
on May 31, 2017 at 11:42:54 pm
My first thought would be to delete all the render files and try again.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Noah Kadner
on Jun 1, 2017 at 12:02:22 am
Can occur when there's a bad piece of source media- but yeah blowing away renders will probably clear this out.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Ken Bennett
on Jun 1, 2017 at 2:14:43 am
I did delete all rendered files, toggled the codec, let it rebuild the needed rendered files and my Shared MP4 was processed completely.
Thanks.
Ken Bennett
Video Adventures
Jeremy Garchow
on Jun 2, 2017 at 2:45:25 am
[Ken Bennett] "let it rebuild the needed rendered files"
For next time, there's no reason to render first, you can share without rendering.
Mark Suszko
on Jun 2, 2017 at 4:25:40 am
I have not always found that to be the case, Jeremy. As you can see in my question above.
