Multicam Problem: 2 cams/different frame rates
Joseph Murray
on May 27, 2017 at 5:34:18 pm
Pretty standard problem; 2 camera multi cam shoot; Camera 1 was recording at 24fps, Camera 2 was recording at 23.976. The takes are 10-20 min long and the audio sync starts to drift and I don't want to start pulling frames and syncing by hand.
What is the best solution to converting one of the cameras to the correct frame rate?
Which camera should be converted? Better to go 23.976 to 24 or 24 to 23.976.?
Will the quality be better in Compressor than the drag and drop method in FCP X?
Thanks, Joe
Joe Murray
Directors Guild Of America-Director
Int'l Cinematographers Guild -Director of Photography
http://www.nativesonsfilms.com
Noah Kadner
Re: Multicam Problem: 2 cams/different frame rates
on May 28, 2017 at 6:25:06 am
What is the final delivery format?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Joseph Murray
on May 28, 2017 at 3:25:16 pm
Hey Noah...1080p for the web
Joe Murray
Noah Kadner
on May 28, 2017 at 4:15:39 pm
I'd suggest experimenting with conforming to either frame rate. Since it's for the web it doesn't really matter which tinecode you land on- more which syncs.
Noah
