Dropped frames
Dan Rayner
Dropped frames
on May 23, 2017 at 10:58:04 am
Hi All - I've been cutting a project on my MBP 2.7GHz 16GB RAM GeForce GT 650M 1024MB graphics.
The timeline consists of a 2 angle multi cam clip, one of which is 4k, the other 1080p, all prores.
It plays back fine on the laptop.
When i move to my iMac 4K, 2GB graphics, 32MB RAM (i.e. a much more powerful computer), the project won't play without lots of dropped frames.
Any ideas?
Thanks guys and gals.
Dirk de Jong
Re: Dropped frames
on May 23, 2017 at 12:27:16 pm
This may be kind of obvious so you might've already done these things but....
- set the View menu to "Better Performance" and to use Proxy media if there is proxy media
- if there is not proxy media transcode clips to create proxy media
- maybe set Preferences to create optimized media for Multicam clips since you say you're using multicam ?
- set prefs not to stop and warn if the occasional dropped frame becomes too distracting
Dan Rayner
Re: Dropped frames
on May 23, 2017 at 2:58:07 pm
Hi Dirk - sorry I meant to say that it plays back fine with optimised media on the MBP.
Closing the angle viewer seems to have made the issue go away.
Thanks again
D
