Is there any way to connect clips that were edited as 30fps to the same clips reverse telecined to 24fps?
Noam Osband
on May 20, 2017 at 1:39:50 am
I did reverse telecine on these clips in Compressor. I had logged and edited with the clips at 30 fps. If I try to relink those clips to the version that is now 24fps, FCP X doesn't let me relink. It tries to relink but tells me they're incompatible.
I'm guessing there's no work around. But i figured I'd ask first. Is there any way to connect the logging I did to the new clips?
Jeff Kirkland
Re: Is there any way to connect clips that were edited as 30fps to the same clips reverse telecined to 24fps?
on May 20, 2017 at 3:23:26 am
No workaround I'm afraid. For FCPX to relink the files must be the same size, frame rate, etc.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Noah Kadner
on May 20, 2017 at 4:45:47 am
Other than manually overcutting- but no you can't 'force relink' in X.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
