"Page Turns" Fail in Compound Clips
Ken Bennett
on May 19, 2017 at 3:33:14 pm
I’ve put FCPX page turn transitions in a Project. They playback fine in the original Project. But once I make the Project into a Compound Clip these page turns do not work as designed. Instead of seeing the page turn start in the corner, it starts several frames into the page turn. And near the end it just stops or freezes for several frames and doesn't complete the page turn. This tells me I can't use Compound Clips in FCPX if I have transitions.
Compound Clip
http://iplayerhd.com/player/video/26fd7441-a854-4917-9c3a-fdcea595c346/shar...
Original Project Clip
http://iplayerhd.com/player/video/49746265-dff6-4881-82e8-12d5ee033d03/shar...
Ken Bennett
Video Adventures
Capturing Your Life's Adventures!
Jeff Kirkland
Re: "Page Turns" Fail in Compound Clips
on May 19, 2017 at 10:06:35 pm
Well, it tells you that you can't use page turns in a compound clip. Report it to Apple.
Meanwhile, I assume all is well if you just break apart the compound clip before you render the final video?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Ken Bennett
on May 19, 2017 at 11:09:16 pm
That's a good one. Something I'd say.
When I DO break it open it seems to be fine. So today's lesson, break apart my Compound clips before that final SHARE.
Thanks BTW.
Ken Bennett
Video Adventures
Ken Bennett
on May 19, 2017 at 11:27:02 pm
But come to find, when I break apart my Compound Clip in my master Project's timeline, it opens a new timeline of just my Compound Clip. So that gets me nowhere.
Ken Bennett
Video Adventures
Ken Bennett
on May 19, 2017 at 11:33:25 pm
Actually when I use the command Break Apart, that removes all transitions.
Ken Bennett
Video Adventures
